Posted at 4/27/2016 10:25:48
you need to make an sdcard boot using the other script on mara's site then mount mmcblk1p1 and format as ext4 and then dd or similar the image to that partition then refresh just the boot loader, parameter, kernel and boot.img to the correct hex offsets and it should boot from emac.
i fiddled around with this for days but this build is broken and overtime i try to update the installed slackware it just breaks the system so i wouldn't bother with this until either mara makes some update to fix that along with the mts issue too or just install and don't run slackpkg update-all
I'm hoping someone smarter then myself can use this kernel build with a debian/ubuntu rootfs |
