[General] Latest Test HPE6-A78 Simulations | HPE6-A78 Exam Fee
97
【General】 Latest Test HPE6-A78 Simulations | HPE6-A78 Exam Fee
Posted at 2/15/2026 18:59:13      View:91 | Replies:1        Print      Only Author   [Copy Link] 1#
P.S. Free & New HPE6-A78 dumps are available on Google Drive shared by Prep4away: https://drive.google.com/open?id=11ah08MOtIEZ4WYRPQHxFDUuzyQqH9oYB
What is your dream? Don't you want to make a career? The answer must be ok. Then, you need to upgrade and develop yourself. You worked in the IT industry, through what methods can you realize your dream? Taking IT certification exam and getting the certificate are the way to upgrade yourself. At present, HP HPE6-A78 Exam is very popular. Do you want to get HP HPE6-A78 certificate? If it is ok, don't hesitate to sign up for the exam. And don't worry about how to pass the test, Prep4away certification training will be with you.
HPE6-A78 exam is designed for network security professionals who want to enhance their skills and knowledge in network security and wireless networking. Aruba Certified Network Security Associate Exam certification is ideal for network security engineers, network administrators, security analysts, and wireless network professionals. Aruba Certified Network Security Associate Exam certification is also valuable for organizations that use Aruba products and want to ensure that their network security professionals have the skills and knowledge required to maintain a secure network infrastructure.
The HP HPE6-A78 Exam is designed for individuals who are just starting their careers in network security or those who wish to improve their knowledge of the field. It covers a wide range of topics, including network security fundamentals, secure network design and configuration, and threat mitigation techniques. HPE6-A78 exam is composed of 60 multiple-choice questions, which must be answered within 90 minutes.
100% Pass Quiz 2026 Reliable HPE6-A78: Latest Test Aruba Certified Network Security Associate Exam SimulationsThe Prep4away is one of the leading platforms that has been offering real and valid Aruba Certified Network Security Associate Exam (HPE6-A78) exam practice test questions. These HPE6-A78 exam questions are designed and verified by HP HPE6-A78 subject matter experts. They work closely together and put all their expertise to check the Prep4away HPE6-A78 Exam Questions one by one. So we can say that the Prep4away HPE6-A78 exam practice questions are real, valid, and updated Aruba Certified Network Security Associate Exam (HPE6-A78) exam questions that will provide you with everything that you need to learn to prepare and pass the HPE6-A78 exam.
HP Aruba Certified Network Security Associate Exam Sample Questions (Q56-Q61):NEW QUESTION # 56
What is one benefit of enabling Enhanced Secure mode on an ArubaOS-Switch?
  • A. Control Plane policing rate limits edge ports to mitigate DoS attacks on network servers.
  • B. All interfaces have 802.1X authentication enabled on them by default.
  • C. Insecure algorithms for protocol such as SSH are automatically disabled.
  • D. A self-signed certificate is automatically added to the switch trusted platform module (TPM).
In the context of ArubaOS-Switches, enabling Enhanced Secure mode has several benefits, one of which includes disabling insecure algorithms for protocols such as SSH. This is in line with security best practices, as older, less secure algorithms are known to be vulnerable to various types of cryptographic attacks. When Enhanced Secure mode is enabled, the switch automatically restricts the use of such algorithms, thereby enhancing the security of management access.
NEW QUESTION # 57
You are deploying a new wireless solution with an Aruba Mobility Master (MM). Aruba Mobility Controllers (MCs), and campus APs (CAPs). The solution will include a WLAN that uses Tunnel for the forwarding mode and WPA3-Enterprise for the security option.
You have decided to assign the WLAN to VLAN 301, a new VLAN. A pair of core routing switches will act as the default router for wireless user traffic.
Which links need to carry VLAN 301?
  • A. only links in the campus LAN to ensure seamless roaming
  • B. only links between MC ports and the core routing switches
  • C. only links on the path between APs and the core routing switches
  • D. only links on the path between APs and the MC
In a wireless network deployment with Aruba Mobility Master (MM), Mobility Controllers (MCs), and Campus APs (CAPs), where a WLAN is configured to use Tunnel mode for forwarding, the user traffic is tunneled from the APs to the MCs. VLAN 301, which is assigned to the WLAN, must be present on the links from the MCs to the core routing switches because these switches act as the default router for the wireless user traffic. It is not necessary for the VLAN to be present on all campus LAN links or AP links, only between the MCs and the core routing switches where the routing for VLAN 301 will occur.
NEW QUESTION # 58
You have an Aruba Mobility Controller (MC). for which you are already using Aruba ClearPass Policy Manager (CPPM) to authenticate access to the Web Ul with usernames and passwords You now want to enable managers to use certificates to log in to the Web Ul CPPM will continue to act as the external server to check the names in managers' certificates and tell the MC the managers' correct rote in addition to enabling certificate authentication. what is a step that you should complete on the MC?
  • A. install all of the managers' certificates on the MC as OCSP Responder certificates
  • B. Verify that the MC trusts CPPM's HTTPS certificate by uploading a trusted CA certificate Also, configure a CPPM username and password on the MC
  • C. Create a local admin account mat uses certificates in the account, specify the correct trusted CA certificate and external authentication
  • D. Verify that the MC has the correct certificates, and add RadSec to the RADIUS server configuration for CPPM
NEW QUESTION # 59
A company has added a new user group. Users in the group try to connect to the WLAN and receive errors that the connection has no Internet access. The users cannot reach any resources. The first exhibit shows the record for one of the users who cannot connect. The second exhibit shows the role to which the ArubaOS device assigned the user's client.
What is a likely problem?
  • A. The ArubaOS device has a server derivation rule configured on it that has overridden the role sent by CPPM.
  • B. The ArubaOS device does not have the correct RADIUS dictionaries installed on it to under-stand the Aruba-User-Role VSA.
  • C. The clients rejected the server authentication on their side because they do not have the root CA for CPPM's RADIUS/EAP certificate.
  • D. The role name that CPPM is sending does not match the role name configured on the Aru-baOS device.
The image indicates that there is an issue with the user role assignment, which is key to network access in ArubaOS. If the user role name sent by CPPM doesn't match any of the roles defined in the ArubaOS, then the user will be assigned a default or incorrect role that does not have the necessary permissions, thus leading to the connection errors and lack of Internet access. Ensuring that the role names are consistent between CPPM and ArubaOS can resolve this issue.
NEW QUESTION # 60
What is a guideline for deploying Aruba ClearPass Device Insight?
  • A. For companies with multiple sites, deploy a pair of Device Insight Collectors at the HQ or the central data center.
  • B. Configure remote mirroring on access layer Aruba switches, using Device Insight Analyzer as the destination IP.
  • C. Deploy a Device Insight Collector at every site in the corporate WAN to reduce the impact on WAN links.
  • D. Make sure that Aruba devices trust the root CA certificate for the ClearPass Device Insight Analyzer's HTTPS certificate.
For deploying Aruba ClearPass Device Insight effectively, especially in environments with multiple sites, it is recommended to deploy a pair of Device Insight Collectors at the headquarters or the central data center.
This deployment strategy helps in centralizing the data collection and analysis, which simplifies management and enhances performance by reducing the data load on the WAN links connecting different sites.
Centralizing the collectors at a major site or data center allows for better scalability and reliability of the network management system. This configuration also aids in achieving a more consistent and comprehensive monitoring and analysis of the devices across the network, ensuring that the security and management policies are uniformly applied. This recommendation is based on best practices for network architecture design, particularly those discussed in Aruba's deployment guides and network management strategies.
NEW QUESTION # 61
The second format of Aruba Certified Network Security Associate Exam (HPE6-A78) is the web-based practice exam that can be taken online through browsers like Firefox, Chrome, Safari, MS Edge, Internet Explorer, and Microsoft Edge. You don't need to install any excessive plugins or Software to attempt the web-based Practice HPE6-A78 Exam. All operating systems also support the web-based practice exam.
HPE6-A78 Exam Fee: https://www.prep4away.com/HP-certification/braindumps.HPE6-A78.ete.file.html
What's more, part of that Prep4away HPE6-A78 dumps now are free: https://drive.google.com/open?id=11ah08MOtIEZ4WYRPQHxFDUuzyQqH9oYB
Posted at 2/20/2026 18:44:39        Only Author  2#
This article is so encouraging, thanks for sharing it! Best of luck! Sharing the CCFA-200b reasonable exam price materials with you all.
