[General] MikroTik MTCNA認證指南 -最新MTCNA考古題
104
【General】 MikroTik MTCNA認證指南 -最新MTCNA考古題
Posted at 2/18/2026 08:47:45      View:103 | Replies:0        Print      Only Author   [Copy Link] 1#
順便提一下,可以從雲存儲中下載NewDumps MTCNA考試題庫的完整版:https://drive.google.com/open?id=1B9WWwj9Bju7JDBP4n9USGMr78eRdlx9-
為了通過MikroTik MTCNA 認證考試,請選擇我們的NewDumps來取得好的成績。你不會後悔這樣做的,花很少的錢取得如此大的成果這是值得的。我們的NewDumps不僅能給你一個好的考試準備,讓你順利通過MikroTik MTCNA 認證考試,而且還會為你提供免費的一年更新服務。
為了讓你們更放心地選擇NewDumps,NewDumps的最佳的MikroTik MTCNA考試材料已經在網上提供了部分免費下載,你可以免費嘗試來確定我們的可靠性。我們不僅可以幫你一次性地通過考試,同時還可以幫你節約寶貴的時間和精力。NewDumps能為你提供真實的 MikroTik MTCNA認證考試練習題和答案來確保你考試100%通過。通過了MikroTik MTCNA 認證考試你的地位將在IT行業中也有很大的提升,你的明天也會跟那美好。
最新版的MTCNA認證指南,免費下載MTCNA學習資料得到妳想要的MikroTik證書NewDumps是一個學習MikroTik技術的人們都知道的網站。它受到了參加MTCNA認定考試的人的一致好評。這是一個可以真正幫助到大家的網站。為什麼NewDumps能得到大家的信任呢?那是因為NewDumps有一個MikroTik業界的精英團體,他們一直致力於為大家提供最優秀的考試資料。因此,NewDumps可以给大家提供更多的优秀的MTCNA参考书,以满足大家的需要。
最新的 MTCNA - MikroTik Training MTCNA 免費考試真題 (Q95-Q100):問題 #95
How long is level 1 (demo) license valid?
  • A. 1 year
  • B. 24 hours
  • C. Infinite time
  • D. 1 month
答案:C
解題說明:
RouterOS Level 1 license is the demo license that comes with all RouterOS installations (particularly on x86 or CHR before activation). It is unrestricted in time, meaning it never expires, but functionality is extremely limited.
* A. 24 hours # Incorrect. There is no such time-limited restriction.
* B. Infinite time # Correct. Level 1 license is perpetual but has limited features.
* C. 1 month # Incorrect. MikroTik does not impose monthly timeouts on license levels.
* D. 1 year # Incorrect. No temporary time-bound license is assigned by default.
Extract from Official MTCNA Course Material - Licensing Section:
"Level 1 (demo) license is unlimited in time but has very limited functionality. It is designed for testing purposes only." Extract from Rene Meneses MTCNA Study Guide - RouterOS Licensing:
"The Level 1 license is not time-limited, but it cannot be used in production due to its lack of key features." Extract from MikroTik Wiki - Licensing Model:
"License level 1 is a free demo license that does not expire."
問題 #96
How often are BPDUs sent from a Layer 2 device?
  • A. Every 10 minutes
  • B. Every 30 seconds
  • C. Every 2 seconds
  • D. Never
答案:C
解題說明:
BPDU (Bridge Protocol Data Units) are messages exchanged by switches in a Spanning Tree Protocol (STP) topology to maintain loop-free Layer 2 networks. By default, switches send BPDUs every 2 seconds.
MTCNA Course Material - STP Operation:
"Switches send BPDUs to maintain spanning tree and detect topology changes. The default transmission interval is 2 seconds." Cisco STP Documentation:
"BPDUs are transmitted by the root bridge and propagated every 2 seconds by default, controlled by the hello- time timer." Other options:
* A: Incorrect - BPDUs are essential for loop prevention
* C & D: Not correct - default is 2 seconds, not minutes
問題 #97
When using routing option check-gateway=ping, after how many timeouts is the gateway considered unreachable?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
答案:C
解題說明:
In MikroTik RouterOS, if you enable check-gateway=ping on a static route, RouterOS sends periodic ICMP echo requests (ping) to the specified gateway.
By default, the gateway is considered unreachable after:
* 2 consecutive ping timeouts ##
This status will cause the router to remove the route from the routing table until the gateway responds again.
Evaluations:
* A. 4 ##Too many
* B. 1 ##Too sensitive; only one timeout doesn't mark it unreachable
* C. 2 ##Correct default behavior
* D. 3 ##Incorrect default
MTCNA Course Manual - Gateway Checking:
"When using check-gateway=ping, the router waits for two failed pings before declaring the route inactive." Rene Meneses Study Guide - Static Routing Behavior:
"check-gateway=ping disables the route after two ping failures."
Terry Combs Notes - Route Monitoring:
"Ping-based route checks fail after 2 missed responses - that route becomes inactive."
問題 #98
Netinstall can be used to
  • A. Reinstall software without losing licence
  • B. Install different software version (upgrade or downgrade)
  • C. Keep configuration, but reset a lost admin password
  • D. Install package for different hardware architecture
答案:A,B
解題說明:
Netinstall is a MikroTik utility used to reinstall or repair RouterOS on RouterBOARD devices. It can be used to:
* Reinstall RouterOS while preserving the existing license (#B)
* Install a different version of RouterOS - either older or newer (#C)
Limitations:
* A.#Incorrect - Netinstall will erase the configuration; it cannot recover a lost admin password without wiping the device.
* D.#Incorrect - You can only install software meant for the specific hardware architecture of the RouterBOARD.
Extract from Official MTCNA Course Material - Netinstall Tool:
"Netinstall can be used to reinstall RouterOS and change its version. It does not erase the license key." Extract from Rene Meneses MTCNA Study Guide - Recovery Tools:
"Netinstall allows you to load any RouterOS version compatible with your device. It does not delete the license." Extract from MikroTik Wiki - Netinstall Overview:
"Netinstall reinstalls the OS, can change versions, and retains license. It cannot recover configuration or passwords."
問題 #99
What does this simple queue do (check the image)?
  • A. Queue guarantees download data rate of one megabit per second for host 192.168.1.10
  • B. Queue limits host 192.168.1.10 download data rate to one megabit per second.
  • C. Queue guarantees upload data rate of one megabit per second for host 192.168.1.10
  • D. Queue limits host 192.168.1.10 upload data rate to one megabit per second.
答案:D
問題 #100
為什麼要 MikroTik MTCNA 認證?獲得 MTCNA 認證將證明你的專業技能和貢獻,並對你的職業生涯大有裨益。服務提供商們對有資格認證的網路工程人員的需求在迅速增加,並在激烈的競爭以搶奪有資格認證的Internet專家和專門人才。如果你是一個技術員、工程師或科學家,並有使用 MikroTik 網路公司產品和平臺的經驗,那麼你在這個領域中前進的機會實際上是無限的。全世界的Internet服務商的價值都會因你的加入而提高。MikroTik 網路公司的服務提供商計畫也要求 MikroTik 網路公司的合作夥伴雇傭一定數量的認證工程。作為優秀的員工,這是為了保證你的服務水準,並能使你區別於一般的人。
最新MTCNA考古題: https://www.newdumpspdf.com/MTCNA-exam-new-dumps.html
也因此MTCNA認證考試變得越來越火熱,參加MTCNA考試的人也越來越多,但是MTCNA認證考試的通過率並不是很高,MikroTik MTCNA認證指南 這個資料的價值等同於其他一切的與考試相關的參考書,對於為了進入大中型IT公司的畢業生來說,不想花費太多的錢去補習,只能借助於最新的NewDumps MTCNA考題准備考試,因為這類考題在網路中的價錢不是很高,你很快就可以獲得MikroTik MTCNA 認證考試的證書,這是能夠幫你100%通過MTCNA考試的學習資料,如果你不小心沒有通過MikroTik Certified Network Associate Exam - MTCNA認證考試,我們保證會全額退款,談到MikroTik的MTCNA考試,NewDumps MikroTik的MTCNA的考試培訓資料一直領先於其他的網站,因為NewDumps有一支強大的IT精英團隊,他們時刻跟蹤著最新的 MikroTik的MTCNA的考試培訓資料,用他們專業的頭腦來專注於 MikroTik的MTCNA的考試培訓資料。
在零碎的拼湊下,他們也是知道了壹些經過,桑梔沒有再堅持,也因此MTCNA認證考試變得越來越火熱,參加MTCNA考試的人也越來越多,但是MTCNA認證考試的通過率並不是很高,這個資料的價值等同於其他一切的與考試相關的參考書。
只有最好的MTCNA認證指南才能提供MikroTik Certified Network Associate Exam的最高通過率對於為了進入大中型IT公司的畢業生來說,不想花費太多的錢去補習,只能借助於最新的NewDumps MTCNA考題准備考試,因為這類考題在網路中的價錢不是很高,你很快就可以獲得MikroTik MTCNA 認證考試的證書。
這是能夠幫你100%通過MTCNA考試的學習資料,如果你不小心沒有通過MikroTik Certified Network Associate Exam - MTCNA認證考試,我們保證會全額退款。
此外,這些NewDumps MTCNA考試題庫的部分內容現在是免費的:https://drive.google.com/open?id=1B9WWwj9Bju7JDBP4n9USGMr78eRdlx9-
