Microsoft SC-401 Questions To Gain Brilliant Result [2026]
Posted at 3/7/2026 06:03:04
P.S. Free 2026 Microsoft SC-401 dumps are available on Google Drive shared by DumpsMaterials: https://drive.google.com/open?id=1UB_meABIP0gQZ9ndKzEZ1ydOIAtEHEIE
We understand our candidates have no time to waste, everyone wants an efficient learning. So we take this factor into consideration, develop the most efficient way for you to prepare for the SC-401 exam, that is the real questions and answers practice mode, firstly, it simulates the real Administering Information Security in Microsoft 365 test environment perfectly, which offers greatly help to our customers. Secondly, it includes printable PDF Format, also the instant access to download make sure you can study anywhere and anytime. All in all, high efficiency of SC-401 Exam Material is the reason for your selection.
Although a lot of products are cheap, but the quality is poor, perhaps users have the same concern for our latest SC-401 exam dump. Here, we solemnly promise to users that our product error rate is zero. Everything that appears in our products has been inspected by experts. In our SC-401 practice materials, users will not even find a small error, such as spelling errors or grammatical errors. It is believed that no one is willing to buy defective products, so, the SC-401 Study Guide has established a strict quality control system. The entire compilation and review process for latest SC-401 exam dump has its own set of normative systems, and the SC-401 practice materials have a professional proofreader to check all content. Only through our careful inspection, the study material can be uploaded to our platform. So, please believe us, 0 error rate is our commitment.
SC-401 Dumps - SC-401 Valid Test CostUsers do not need to spend too much time on SC-401 questions torrent, only need to use their time pieces for efficient learning, the cost is about 20 to 30 hours, users can easily master the test key and difficulties of questions and answers of SC-401 Prep Guide, and in such a short time acquisition of accurate examination skills, better answer out of step, so as to realize high pass the qualification test, has obtained the corresponding qualification certificate.
Microsoft Administering Information Security in Microsoft 365 Sample Questions (Q170-Q175):NEW QUESTION # 170
Hotspot Question
You have a Microsoft 365 E5 subscription that contains the data loss prevention (DLP) policies shown in the following table.
You have a custom employee information form named Template1.docx.
You plan to create a sensitive info type named Sensitive1 that will use the document fingerprint from Template1.docx.
What should you use to create Sensitive1, and in which DLP policies can you use Sensitive1? To answer, select the appropriate options in the answer area.
Box 1: Microsoft Purview portal
Box 2: DLP1, DLP2, and DLP3
DLP can use document fingerprinting as a detection method in Exchange, SharePoint, OneDrive, Teams, and Devices.
https://learn.microsoft.com/en-u ... ment-fingerprinting
NEW QUESTION # 171
You have a data loss prevention (DIP) policy that has the advanced DIP rules shown in the following table.
You need to identity which rules will apply when content matches multiple advanced DIP rules.
Which rules should you identify? To answer, select the appropriate options in the answer area.
NEW QUESTION # 172
You have a Microsoft 365 subscription.
You have a user named User1. Several users have full access to the mailbox of User1.
Some email messages sent to User1 appear to have been read and deleted before the user viewed them.
When you search the audit log in the Microsoft Purview portal to identify who signed in to the mailbox of User1, the results are blank.
You need to ensure that you can view future sign-ins to the mailbox of User1.
Solution: You run the Set-AdminAuditLogConfig -AdminAuditLogEnabled $true -AdminAuditLogCmdlets *Mailbox* command.
Does that meet the goal?
The Set-AdminAuditLogConfig -AdminAuditLogEnabled $true -AdminAuditLogCmdlets *Mailbox* command is incorrect. This enables admin audit logging, which tracks changes to mailbox configurations (e.g., mailbox settings updates), not user activity inside the mailbox.
NEW QUESTION # 173
You have a Microsoft 365 E5 subscription.
You plan to implement Microsoft Purview insider risk management.
You implement the HR data connector.
You need to prepare the data that will be imported by the data connector.
In which format should you prepare the data?
- A. XML
- B. PRN
- C. TSV
- D. CSV
- E. JSON
When implementing Microsoft Purview Insider Risk Management and using the HR data connector, you must prepare HR data in CSV (Comma-Separated Values) format. This format is required because Microsoft Purview supports CSV files for importing user employment details, termination dates, role changes, and other HR-related attributes.
NEW QUESTION # 174
SIMULATION
Username and password
Use the following login credentials as needed:
To enter your username, place your cursor in the Sign in box and select the username below.
To enter your password, place your cursor in the Enter password box and select the password below.
Microsoft 365 Username:
admin@WWLx121586.onmicrosoft.com
Microsoft 365 Password: XXXXXXXXX
If the Microsoft Edge browser or Microsoft 365 portal does not load successfully, select the Microsoft Edge browser icon from the task bar, type the URL "https://admin.microsoft.com", and press Enter.
The following information is for technical support purposes only:
Lab Instance: XXXXXXXXX
Task 1
You plan to implement Endpoint data loss prevention (Endpoint DLP). You plan to create a policy that will restrict OneDrive.exe from accessing files that have the Highly Confidential sensitivity label.
You need to configure the Endpoint DLP settings so that onedrive.exe actions can be restricted by a DLP policy.
You do NOT need to create a DLP policy at this time.
To restrict onedrive.exe actions in Microsoft Purview, you first configure it as a restricted app group in Endpoint DLP settings and then add that group to a DLP policy in the Microsoft Purview portal. In the Endpoint DLP settings, navigate to Data loss prevention > Settings > Data loss prevention > Endpoint settings > Restricted apps and app groups. Create a new group called
"Cloud Sync apps," select the Auto-quarantine option, and add onedrive.exe as the executable name for Windows.
Configure the restricted app group
Step 1: Sign in to the Microsoft Purview portal.
Step 2: Go to Data loss prevention > Settings (gear icon) > Data loss prevention > Endpoint settings.
Step 3: Expand Restricted apps and app groups.
Step 4: Under "Restricted app groups," select Add restricted app group.
Step 5: Enter a group name, such as Cloud Sync apps.
Step 6: Check the box for Auto-quarantine.
Step 7: In the "App name" field, add the executable name:
For Windows, enter onedrive.exe and click the + button.
https://learn.microsoft.com/en-us/purview/endpoint-dlp-using
NEW QUESTION # 175
Our SC-401 valid practice questions are designed by many experts in the field of qualification examination, from the user's point of view, combined with the actual situation of users, designed the most practical SC-401 learning materials. We believe that no one will spend all their time preparing for SC-401 Exam, whether you are studying professional knowledge, or all of which have to occupy your time to review the exam. Using the SC-401 test prep, you will find that you can grasp the knowledge what you need in the exam in a short time.
SC-401 Dumps: https://www.dumpsmaterials.com/SC-401-real-torrent.html
Besides, each questions of SC-401 valid exam dumps are selected and verified by specialized person according to the strict standards, thus the SC-401 Administering Information Security in Microsoft 365 actual questions you get are the authoritative and deserves your trust, So Microsoft SC-401 Dumps study materials promise absolutely quality which preserves candidates' benefits as well as its own reputation, Also you will find that most of our Microsoft SC-401 exam bootcamp have 85% similarity or above with the real questions of real test after you purchase our products.
Notice that the image still looks good at each of these settings, Valid SC-401 Test Notes but the file size is significantly smaller each time you reduce the number of colors, I have to track service quality over time.
New Launch SC-401 Administering Information Security in Microsoft 365 Dumps Options To Pass the Exam 2026Besides, each questions of SC-401 Valid Exam Dumps are selected and verified by specialized person according to the strict standards, thus the SC-401 Administering Information Security in Microsoft 365 actual questions you get are the authoritative and deserves your trust.
So Microsoft study materials promise absolutely quality SC-401 which preserves candidates' benefits as well as its own reputation, Also you will find that most of our Microsoft SC-401 exam bootcamp have 85% similarity or above with the real questions of real test after you purchase our products.
Are you ready to add the SC-401 certification to your resume, Both are the Prepare for your SC-401 practice exams that will give you a real-time Administering Information Security in Microsoft 365 (SC-401) exam environment for quick SC-401 exam preparation.
- SC-401 Test Discount 🩲 SC-401 Detail Explanation 🦰 Exam Sample SC-401 Questions 🍷 Copy URL 《 [url]www.troytecdumps.com 》 open and search for ➽ SC-401 🢪 to download for free ☔Exam SC-401 Dumps[/url]
- Free PDF 2026 Microsoft SC-401: Administering Information Security in Microsoft 365 –The Best Valid Test Notes 🎵 The page for free download of 【 SC-401 】 on ➡ [url]www.pdfvce.com ️⬅️ will open immediately 🎉SC-401 Test Answers[/url]
- SC-401 Valid Test Sample 📿 SC-401 Latest Test Bootcamp 🐾 Exam Sample SC-401 Questions 🙁 Copy URL ▛ [url]www.practicevce.com ▟ open and search for ⇛ SC-401 ⇚ to download for free 🌉SC-401 Detail Explanation[/url]
- SC-401 Latest Test Bootcamp 🥻 Examcollection SC-401 Dumps Torrent 🐊 SC-401 Test Answers 🚝 Go to website ( [url]www.pdfvce.com ) open and search for 「 SC-401 」 to download for free 🛃Valid SC-401 Exam Pattern[/url]
- Pass Guaranteed Quiz 2026 The Best Microsoft Valid SC-401 Test Notes 🔽 Easily obtain free download of ▛ SC-401 ▟ by searching on ☀ [url]www.examcollectionpass.com ️☀️ 🍿Exam SC-401 Tutorial[/url]
- Reliable and Guarantee Refund of Microsoft SC-401 Exam Dumps According to Terms and Conditions 💻 Search for ➠ SC-401 🠰 and download it for free immediately on ✔ [url]www.pdfvce.com ️✔️ 🔌New SC-401 Exam Pattern[/url]
- SC-401 Authorized Pdf 😹 Exam SC-401 Training 😉 Latest SC-401 Test Voucher 🤪 Search for 「 SC-401 」 and easily obtain a free download on 《 [url]www.vce4dumps.com 》 🍒SC-401 Detail Explanation[/url]
- Reliable and Guarantee Refund of Microsoft SC-401 Exam Dumps According to Terms and Conditions 📎 Easily obtain ( SC-401 ) for free download through ( [url]www.pdfvce.com ) 🕗SC-401 Reliable Test Tips[/url]
- 2026 Excellent 100% Free SC-401 – 100% Free Valid Test Notes | Administering Information Security in Microsoft 365 Dumps 🥧 Download ☀ SC-401 ️☀️ for free by simply searching on ⮆ [url]www.examcollectionpass.com ⮄ 🔴SC-401 Detail Explanation[/url]
- Buy SC-401 Exam Dumps Now and Get Amazing Offers ✔️ Open ⏩ [url]www.pdfvce.com ⏪ and search for ☀ SC-401 ️☀️ to download exam materials for free 🟩Exam SC-401 Training[/url]
- Buy SC-401 Exam Dumps Now and Get Amazing Offers 🌮 Immediately open 《 [url]www.vce4dumps.com 》 and search for 《 SC-401 》 to obtain a free download 🚉Latest SC-401 Test Voucher[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, dakusfranlearning.com, www.stes.tyc.edu.tw, seginternationalcollege.com, wjhsd.instructure.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
BTW, DOWNLOAD part of DumpsMaterials SC-401 dumps from Cloud Storage: https://drive.google.com/open?id=1UB_meABIP0gQZ9ndKzEZ1ydOIAtEHEIE
