[General] Pass Guaranteed Quiz Fortinet - NSE4_FGT_AD-7.6 - Unparalleled Exam Fortinet NSE
28
【General】 Pass Guaranteed Quiz Fortinet - NSE4_FGT_AD-7.6 - Unparalleled Exam Fortinet NSE
Posted at 5/17/2026 16:59:25      View:54 | Replies:0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest ExamsLabs NSE4_FGT_AD-7.6 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=122PS4mhWBI946T5dkZDw9wmsdqYCv7lC
The committed team of the ExamsLabs is always striving hard to resolve any confusion among its users. The similarity between our Fortinet NSE4_FGT_AD-7.6 exam questions and the real Fortinet NSE4_FGT_AD-7.6 certification exam will amaze you. The similarity between the ExamsLabs NSE4_FGT_AD-7.6 pdf questions and the actual NSE4_FGT_AD-7.6 certification exam will help you succeed in obtaining the highly desired Fortinet NSE 4 - FortiOS 7.6 Administrator (NSE4_FGT_AD-7.6) certification on the first go. You will notice the above features in the Fortinet NSE4_FGT_AD-7.6 Web-based format too. There is no need to go through time-taking installations or agitating plugins to use this format.
Do you want to pass your exam just one time? Then choose us, we can do that for you. NSE4_FGT_AD-7.6 exam cram contains both questions and answers, and you can have a quick check after practicing. NSE4_FGT_AD-7.6 exam materials are high-quality, because we have professional team to compile and verify them. In order to build up your confidence for NSE4_FGT_AD-7.6 Training Materials, we are pass guarantee and money back guarantee, and if you fail to pass the exam, we will give you fell refund. We provide you with free update for 365 days, so that you can know the latest information for the exam, and the update version for NSE4_FGT_AD-7.6 exam dumps will be sent to your email automatically.
Free Download Exam NSE4_FGT_AD-7.6 Cram & High-quality Exam NSE4_FGT_AD-7.6 Guide Materials Ensure You a High Passing RateWe believe that the best brands are those that go beyond expectations. They don't just do the job – they go deeper and become the fabric of our lives. Therefore, as the famous brand, even though we have been very successful we have never satisfied with the status quo, and always be willing to constantly update the contents of our NSE4_FGT_AD-7.6 Exam Torrent. Decades of painstaking efforts have put us in the leading position of NSE4_FGT_AD-7.6 training materials compiling market, and the excellent quality of our NSE4_FGT_AD-7.6 guide torrent and high class operation system in our company have won the common recognition from many international customers for us.
Fortinet NSE 4 - FortiOS 7.6 Administrator Sample Questions (Q42-Q47):NEW QUESTION # 42
You have implemented the application sensor and the corresponding firewall policy as shown in the exhibits.
You cannot access any of the Google applications, but you are able to access www.fortinet.com .
What would you do to resolve this issue?
  • A. Add Google .com to the URL category in the security profile.
  • B. Set SSL inspection to deep-content-inspection.
  • C. Move up Google in the Application and Filter Overrides section to set its priority to 1.
  • D. Change the Inspection mode to Proxy-based.
"With these multiple filters, which one has the priority? After the IPS engine examines the traffic stream for a signature match, FortiGate scans packets for matches, in this order, for the application control profile:
1. Application and filter overrides ..."
"Next, the scan checks for application and filter overrides. Because a filter override is configured to block applications that use excessive bandwidth, it blocks all applications using excessive bandwidth , regardless of other categories that allow these applications."
"In this scenario, the filter override (Excessive-Bandwidth) is blocked and, since Dailymotion falls under the excessive bandwidth category, Dailymotion is blocked even though it is set to Monitor in the Application and Filter Overrides section. The priority in which application and filter overrides are placed takes precedence. "
"To allow web filtering, DNS filtering, or application control for HTTPS traffic , you must select an SSL inspection profile with certificate inspection or a deep inspection enabled." Technical Deep Dive:
The problem is not flow-based mode and not the SSL profile. Your firewall policy already has certificate- inspection , and the study guide explicitly says that application control for HTTPS traffic works with certificate inspection or deep inspection . So option B is unnecessary, and option A is unrelated.
The real issue is the override order inside the application sensor:
* Priority 1: Filter = Excessive-Bandwidth , Action = Block
* Priority 2: Vendor = Google , Action = Monitor
FortiGate evaluates overrides from top to bottom and applies the first match . Many Google applications match the Excessive-Bandwidth filter, so they are blocked before the later Google/Monitor override is ever reached. That is why Google apps fail while www.fortinet.com still works.
So the correct fix is to move the Google override above the Excessive-Bandwidth filter , making Google the first match.
A representative CLI-style logic would be:
config application list
edit " default "
config entries
edit 1
set vendor " Google "
set action monitor
next
edit 2
set filter " Excessive-Bandwidth "
set action block
next
end
next
end
That preserves the bandwidth block for other apps while allowing Google applications to match the higher- priority override first.
NEW QUESTION # 43
Refer to the exhibit. An administrator has configured an Application Overrides for the ABC.Com application signature and set the Action to Allow. This application control profile is then applied to a firewall policy that is scanning all outbound traffic. Logging is enabled in the firewall policy. To test the configuration, the administrator accessed the ABC.Com web site several times.
Why are there no logs generated under security logs for ABC.Com?
  • A. The ABC.Com Action is set to Allow.
  • B. The ABC.Com is configured under application profile, which must be configured as a web filter profile.
  • C. The ABC.Com is hitting the category Excessive-Bandwidth.
  • D. The ABC.Com Type is set as Application instead of Filter.
When the action is set to Allow in an application override, traffic matching this override is allowed without generating security logs because it bypasses deeper inspection and blocking.
NEW QUESTION # 44
Refer to the exhibit showing a debug flow output.
Which two conclusions can you make from the debug flow output? (Choose two answers)
  • A. The RPF check fails.
  • B. The default gateway is configured on port2.
  • C. The debug flow is for UDP traffic.
  • D. The matching firewall policy denies the traffic.
According to the FortiOS 7.6 Troubleshooting and Administration guides, the diagnose debug flow command provides a step-by-step trace of how the FortiGate unit processes a packet.
First, the line "find a route: flag=00000000 gw-0.0.0.0 via port2" indicates that during the routing table lookup, the FortiGate matched the destination against its default route (represented by 0.0.0.0) and determined that the egress interface is port2. This confirms that the default gateway for this traffic is reachable via port2 (Statement A).
Second, the debug trace concludes with the messages "policy-2 Is matched, act-drop" and "Denied by forward policy check (policy 2)". This explicitly indicates that the packet successfully matched the criteria for firewall policy ID 2, and the action configured for that policy is set to Deny (Statement D).
Statement B is incorrect because a Reverse Path Forwarding (RPF) failure would be indicated by a specific "reverse path check fail, drop" message, which is absent here. Statement C is incorrect because the output shows "proto=1", which corresponds to ICMP (Ping) traffic. UDP traffic would be identified as protocol 17.
NEW QUESTION # 45
As an administrator you have created an IPS profile, but it is not performing as expected. While testing you got the output as shown in the exhibit What could be the possible reason of the diagnose output shown in the exhibit?
  • A. Administrator entered the command diagnose test application ipsmonitor 5.
  • B. Administrator entered the command diagnose test application ipsmonitor 99.
  • C. There is a no firewall policy configured with an IPS security profile.
  • D. FortiGate entered into IPS fail open state.
The exhibit shows the output of the following command:
diagnose test application ipsmonitor 1
pid = 2044, engine count = 0 (+1)
0 - pid:2074:2074 cfg:1 master:0 run:1
How to interpret this output (FortiOS 7.6 - IPS internals)
ipsmonitor displays the status of IPS engines running on the FortiGate.
engine count = 0 means:
No IPS scanning engines are currently active
IPS is not processing any traffic
In FortiOS, IPS engines are started on demand.
Critical documented behavior
IPS processes are only spawned when at least one firewall policy is configured with an IPS profile and traffic matches that policy.
If no firewall policy references an IPS profile, the IPS engine:
Does not start
Shows engine count = 0
Appears "not working," even though the IPS profile exists
This is exactly what the diagnose output indicates.
Why option A is correct
A . There is no firewall policy configured with an IPS security profile.
Creating an IPS profile alone is not sufficient
IPS must be applied to an active firewall policy
Traffic must match that policy for the IPS engine to run
Otherwise, ipsmonitor will show engine count = 0
This matches FortiOS 7.6 IPS operational behavior.
Why the other options are incorrect
B . Administrator entered the command diagnose test application ipsmonitor 5.
Incorrect.
The exhibit clearly shows ipsmonitor 1
Using a different argument would not explain engine count = 0
C . FortiGate entered into IPS fail open state.
Incorrect.
In fail-open, IPS engines may be bypassed, but they still initialize
engine count = 0 specifically indicates IPS is not in use at all
D . Administrator entered the command diagnose test application ipsmonitor 99.
Incorrect.
The command argument affects debug level, not engine creation
Again, the exhibit shows ipsmonitor 1
NEW QUESTION # 46
FortiGate is integrated with FortiAnalyzer and FortiManager.
When creating a firewall policy, which attribute must an administrator include to enhance functionality and enable log recording on FortiAnalyzer and FortiManager?
  • A. Sequence ID
  • B. Log ID
  • C. Universally Unique Identifier
  • D. Policy ID
In FortiOS 7.6, when FortiGate is integrated with FortiAnalyzer and FortiManager, firewall policies rely on a Universally Unique Identifier (UUID) to ensure proper policy tracking, synchronization, and log correlation across devices.
Why the UUID is required
Every firewall policy in FortiOS has a UUID.
FortiManager uses the UUID to:
Track policies across managed FortiGate devices
Maintain policy consistency during installs and revisions
FortiAnalyzer uses the UUID to:
Correlate logs accurately to the correct firewall policy
Preserve log association even if policy order or policy ID changes
Without a UUID:
Policy-to-log mapping can break
FortiManager cannot reliably manage or synchronize policies
FortiAnalyzer log analysis becomes inconsistent
This is explicitly documented in Fortinet administration and logging architecture references.
B). Policy IDPolicy ID can change when policies are moved and is not reliable for long-term correlation across FortiManager and FortiAnalyzer.
C). Sequence IDSequence ID reflects GUI ordering only and has no role in log correlation.
D). Log IDLog ID is generated per log event, not per firewall policy.
NEW QUESTION # 47
A good brand is not a cheap product, but a brand that goes well beyond its users' expectations. The value of a brand is that the NSE4_FGT_AD-7.6 study materials are more than just exam preparation tool -- it should be part of our lives, into our daily lives. Do this, therefore, our NSE4_FGT_AD-7.6 Study Materials has become the industry well-known brands, but even so, we have never stopped the pace of progress, we have been constantly updated the NSE4_FGT_AD-7.6 study materials.
Exam NSE4_FGT_AD-7.6 Guide Materials: https://www.examslabs.com/Fortinet/Fortinet-NSE-4/best-NSE4_FGT_AD-7.6-exam-dumps.html
Fortinet Exam NSE4_FGT_AD-7.6 Cram This is the reason that makes our dumps unique and your ultimate requirement, Are you tired of selecting the so-called best NSE4_FGT_AD-7.6 practice questions: Fortinet NSE 4 - FortiOS 7.6 Administrator from all kinds of study materials, Fortinet Exam NSE4_FGT_AD-7.6 Cram Simulation for the software version, Fortinet Exam NSE4_FGT_AD-7.6 Cram Therefore you can handle the questions in the real exam like a cork.
The last decade has seen significant progress in the development of NSE4_FGT_AD-7.6 techniques for resisting software piracy and tampering, It is creating opportunities for whole new breeds of business ventures.
Fortinet NSE 4 - FortiOS 7.6 Administrator Valid Torrent & NSE4_FGT_AD-7.6 Vce Cram & Fortinet NSE 4 - FortiOS 7.6 Administrator Actual Cert TestThis is the reason that makes our dumps unique and your ultimate requirement, Are you tired of selecting the so-called best NSE4_FGT_AD-7.6 Practice Questions: Fortinet NSE 4 - FortiOS 7.6 Administrator from all kinds of study materials?
Simulation for the software version, Therefore Exam NSE4_FGT_AD-7.6 Guide Materials you can handle the questions in the real exam like a cork, If you need ExamsLabs's Fortinet NSE4_FGT_AD-7.6 exam training materials, you can use part of our free questions and answers as a trial to sure that it is suitable for you.
P.S. Free & New NSE4_FGT_AD-7.6 dumps are available on Google Drive shared by ExamsLabs: https://drive.google.com/open?id=122PS4mhWBI946T5dkZDw9wmsdqYCv7lC
