Posted at 1/7/2016 18:31:35
Hi Isle,
Thanks alot for the explanation...It's very great job that you've done.
I try to modify source code in order to decode 4K. As a result i always get errors before decoding. This is the log :
- Firefly@firefly:~/Downloads/firefly-vpu-linux$ ./ffplay Astra_Canal_UHD.ts
- ffplay version 2.6.3 Copyright (c) 2003-2015 the FFmpeg developers
- built with gcc 4.8 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04)
- configuration: --enable-shared --prefix=/usr --disable-ffmpeg --disable-ffprobe --disable-ffserver --disable-static
- libavutil 54. 20.100 / 54. 20.100
- libavcodec 56. 26.100 / 56. 26.100
- libavformat 56. 25.101 / 56. 25.101
- libavdevice 56. 4.100 / 56. 4.100
- libavfilter 5. 11.102 / 5. 11.102
- libswscale 3. 1.101 / 3. 1.101
- libswresample 1. 1.100 / 1. 1.100
- [hevc @ 0xb3922dc0] nb threads_frame = 1, nb threads_slice 1, thread_type = null
- [hevc @ 0xb3908220] nb threads_frame = 1, nb threads_slice 1, thread_type = null
- [hevc @ 0xb3922880] nb threads_frame = 1, nb threads_slice 1, thread_type = null
- [hevc_rkvpu @ 0xb39044a0] PPS id out of range: 0
- [hevc @ 0xb3908220] PPS id out of range: 0
- [hevc @ 0xb3908220] Error parsing NAL unit #2.
- Error while decoding frame
- get frame failed ret -1004
- Something wrong during decode!!!
- Last message repeated 2 times
- get frame failed ret -10040 aq= 0KB vq= 0KB sq= 0B f=0/0
Copy the code
