Arch Linux ARM
35
Arch Linux ARM
Posted at 5/7/2017 23:23:41      View:10024 | Replies:8        Print      Only Author   [Copy Link] 1#
Hi, is there a way to install Arch Linux ARM on Firefly RK3399? I've searched the forums but could not find anything on that matter but for RK3388.
super moderator
Rank: 8Rank: 8
Posted at 5/11/2017 10:41:40        Only Author  2#
Yeah, you can install Arch Linux  ARM like the ubuntu, http://wiki.t-firefly.com/index. ... Build_Ubuntu_rfs/en
Posted at 5/15/2017 22:27:15        Only Author  3#
ok i managed to create the img file. the next step would be to flash it. is there any risk involve like damaging/brik the board?
#EDIT: I flashed the img but it's not working at all!
What i wanna do is install Arch Linux ARM from https://archlinuxarm.org with http://os.archlinuxarm.org/os/ArchLinuxARM-aarch64-latest.tar.gz
I'd be thankful for any help
super moderator
Rank: 8Rank: 8
Posted at 5/16/2017 09:56:52        Only Author  4#
hi,
where is no risk to flash a image to the board,.
oh, did the kernel run ? find  any rootfs? you can get some information in serial debug :
http://wiki.t-firefly.com/index. ... 399/Serial_debug/en
Posted at 5/16/2017 15:58:54        Only Author  5#
No it did not. I also tried the old Arch Linux guide based on RK3388 but it's the same game.. meaning it's not working at all.
Posted at 9/3/2017 13:30:52        Only Author  6#
I am also trying to install arch linux arm. I have followed the instructions at http://wiki.t-firefly.com/index. ... Build_Ubuntu_rfs/en but don't know where to go from here.
vip
Rank: 6Rank: 6
Posted at 12/4/2019 16:58:22        Only Author  7#
Arch linux can be booted with kernels 5.3 and 5.4. For SD boot you need to create usual rootfs, but you need to change firefly dtb before you can boot: this patch allows you not to stuck at boot, also you will need to set
  1. status="okay"
Copy the code
in hdmi_sound node if you want to have sound. Finally, to make boot process faster than 2 minutes, see Manjaro kernel patch for rk3399
If you want to see boot log via serial console, add following to your kernel command line:
  1. console=ttyS2,1500000n8 earlycon=uart8250,mmio32,0xff1a0000
Copy the code
(there is no ttyFIQ0 in mainline kernel)
vip
Rank: 6Rank: 6
Posted at 12/12/2019 17:50:54        Only Author  8#
Hi @phkr, where's the Manjaro kernel patch for rk3399,  could you give a pointer?
vip
Rank: 6Rank: 6
Posted at 12/12/2019 18:52:26        Only Author  9#
penguin Posted at 12/12/2019 12:50
Here it is
