Changing U-boot environment variable
25
Posted at 9/10/2015 18:36:29      View:4201 | Replies:4        Print      Only Author   [Copy Link] 1#
Hello All,
I have added extra environment variable in rockchip u-boot. I can modify and save its value at uboot prompt through setenv and sa option. Further, I want to change u-boot env varaible once I entered into rootfs. I guess there is u-boot utility fw_setenv by which we can set u-boot env. Does any one has compiled this fw_setenv tool for rk3288.
Thanks
Posted at 9/11/2015 15:40:50        Only Author  2#
You might have to compile it yourself.
If you encounter any problem, you can post it here.
Posted at 9/14/2015 11:28:21        Only Author  3#
Thanks for reply, ok I will give it a try and will let you know if encounter any problem.
Posted at 6/29/2017 17:04:29        Only Author  4#
Hi Prash,
    I am using rockchip 3128 (rk3128) in my project, I am new to u-boot. Can you please guide me how to add new environmental variable in u-boot.?
Thanks and Regards
  Shravan S
