Changing U-boot environment variable
25
Posted at 9/10/2015 18:36:29      View:5938 | Replies:6        Print      Only Author   [Copy Link] 1#
Hello All,
I have added extra environment variable in rockchip u-boot. I can modify and save its value at uboot prompt through setenv and sa option. Further, I want to change u-boot env varaible once I entered into rootfs. I guess there is u-boot utility fw_setenv by which we can set u-boot env. Does any one has compiled this fw_setenv tool for rk3288.
Thanks
Posted at 9/11/2015 15:40:50        Only Author  2#
You might have to compile it yourself.
If you encounter any problem, you can post it here.
Posted at 9/14/2015 11:28:21        Only Author  3#
Thanks for reply, ok I will give it a try and will let you know if encounter any problem.
Posted at 6/29/2017 17:04:29        Only Author  4#
Hi Prash,
    I am using rockchip 3128 (rk3128) in my project, I am new to u-boot. Can you please guide me how to add new environmental variable in u-boot.?
Thanks and Regards
  Shravan S
Posted at 1/24/2026 04:45:39        Only Author  5#
Your article is absolutely outstanding, thank you for sharing it! I used the C-P2W43-2023 latest exam duration to achieve a promotion and salary hike. Now, it’s free to all. Hope you all advance in your careers!
Posted at 2/12/2026 04:17:11        Only Author  6#
I appreciate this thought-provoking article, thank you for sharing! Best of luck with your exams—free Valid L5M6 exam bootcamp exam papers are available now!
