New Topic
Firefly New DualBoot Firmware Release(Beta)
1821
super moderator
Rank: 8Rank: 8
Posted at 6/17/2016 14:17:36      View:71503 | Replies:54        Print      Only Author   [Copy Link] 1#
Firefly team focus on the opensource Technology. In our efforts,the New Firmware has released.
New Function:
      New dualboot  mode: (thanks to dewet)
      we add usb keyboard & the POWER KEY to select OS.
Full VGA&HDMI support:
GPU 3D accelerated:
and more...
Dowdload this firmware from here:
googldriver:   https://drive.google.com/open?id=0B7HO8lbGgAqARTV4c24wQTNhQzA
baidupan:      http://pan.baidu.com/s/1c7fqF0
the username&password of this lubuntu : ubuntu&ubuntu.
the Lubuntu single image :
googledriver : https://drive.google.com/open?id=0B7HO8lbGgAqARVZsOTNJVkxrakU
baidupan: http://pan.baidu.com/s/1nu7i9b7
Posted at 6/17/2016 16:27:51        Only Author  2#
Hi,
this is a good news... one question: was it tested with Kodi? Should we expect to have it working out of the box?
And another question: are you planning to release also the Lubuntu image without dual boot?
Thanks,
zeno
Posted at 6/17/2016 17:12:54        Only Author  3#
This looks cool ! I wiil test it !
super moderator
Rank: 8Rank: 8
Posted at 6/17/2016 17:45:29        Only Author  4#
zeno Posted at 6/17/2016 16:27
Hi,
this is a good news... one question: was it tested with Kodi? Should we expect to have it wor ...
Hi zeno:
the kodi can't work smoothly with this version.the GPU havn't worked on it's  full-pow,and also with the VPU . so,we have much more work to do .
We have a plan to fix these problems. however,We're actually a bit short-handed at the moment. The good news is we will build a alliance with some  people who are good at it.
so,if everything goes well . It shouldn't take a very long time to get these problems solved.
yes,the Lubuntu alone image will release very soon.
已有 1评分Prestige +10 Money +11 Contribution +12 Pack up reason
andrewsmithty + 10 + 11 + 12
View all ratings
Posted at 6/17/2016 20:21:58        Only Author  5#
isle Posted at 6/17/2016 17:45
Hi zeno:
the kodi can't work smoothly with this version.the GPU havn't worked on it's  full-pow,a ...
Hi Isle,
yours are great news!
Thanks for continuing the development of the board. I am really looking forward for next single boot lubuntu release.
Cheers,
Zeno
Posted at 6/17/2016 22:10:00        Only Author  6#
Hello Isle,
Thanks for your hard work !
I'd like to ask you some questions :
In this image, the node /dev/dri/card0 exists whereas in the previous ones, it didn't.
What driver is responsible for exporting this node ?
You used armsoc for the X11 graphic driver which is, I believe, an open source driver. Wouldn't the closed source X11 driver from ARM itself work better ?
Also, my screen (hdmi) regularly blacks out, for 1-2 seconds.
super moderator
Rank: 8Rank: 8
Posted at 6/18/2016 09:44:45        Only Author  7#
if somebody get   mistake when update the dualboot image . pls try this on windows system.
AndroidTool_Release_v2.3.rar
925.54 KB, Down times: 5
super moderator
Rank: 8Rank: 8
Posted at 6/18/2016 09:47:07        Only Author  8#
zeno Posted at 6/17/2016 20:21
Hi Isle,
the Lubuntu single image has arrived.
super moderator
Rank: 8Rank: 8
Posted at 6/18/2016 10:16:18        Only Author  9#
Asuuga Posted at 6/17/2016 22:10
Hello Isle,
This image use DRM replaced the rockchip's framebuffer manager. So.the previous ubuntu havn't.
and we will open this source code less than two weeks.
Yes,we know,we use armsoc so  the gpu(maliT760) can run  .
and the hdmi problem,we haven't this appearance. could you give more informations?
Posted at 6/20/2016 15:40:05        Only Author  10#
Hi isle
I send you PM's.
Please see if it can help
Return to List
12345... 6
