Firefly Reload HDMI input custom Android app
28
Posted at 6/20/2016 16:32:22      View:5208 | Replies:2        Print      Only Author   [Copy Link] 1#
Hi,
I need to make a custom Android app that takes HDMI input video & audio from Firefly Reload and plays it. The app has other functionalities which are required in addition to the HDMI input. Is there any documentation/How to for using the HDMI input in Android or can someone direct me to the appropriate code in the Android SDK 'firefly-rk3288_android5.1_git_20150910.tar' from google drive link at http://wiki.t-firefly.com/index. ... wnload_Android_SDK?
Thank You
Posted at 6/20/2016 17:07:43        Only Author  recommend
Hi
After downloading the SDK, you can follow this guide to update the SDK to the latest code, that includes the latest HDMI-IN code.
http://wiki.t-firefly.com/index. ... android_lollipop/en
Here are all the HDMI-IN changes that was made to the SDK:
https://bitbucket.org/T-Firefly/ ... s/all?search=hdmiin
You can search for any word eg. wifi, audio etc in the commits section to see all source code changes for it.
Posted at 6/20/2016 20:20:44        Only Author  3#
Hi
Thanks mo123 for your reply.  I can now look at the source code relevant to the HDMI input.
Unfortunately, I am not quite familiar with Android or Linux kernel dev. But it seems that HDMI input is programmed as a camera HAL. So, just want to confirm if HDMI input device can be used as a standard camera device for Android app development?
