[fireflyP] Python For Firefly Port release
2442
vip
Rank: 6Rank: 6
Posted at 7/23/2016 11:59:58      View5090 | Replies6        Print      Only Author   [Copy Link] 1#
fireflyP is designed for using devices port on firefly or other similar platforms.It can support RK3288 now.
Like GPIO, PWM, SPI and so on.
NOTE: fireflyP is still in development. if you find something wrong, please let me know, and if you fix bugs, it is nice to give me 'Pull requests'
Install
fetch source code:
  1. $ git clone https://github.com/T-Firefly/pyFireflyP.git
  2. $ cd pyFireflyP
Copy the code
install python modules(python can be python2 or python3):
  1. $ sudo python setup.py install
Copy the code
Usage
GPIO and PWM control regs directly by devmem in fireflyP, and independent of kernel space.
The devmem source is modifed from pydevmem(Thanks to Kyle).
You need root privilege to execute it!
Gpio
Interface:
    init()
        Init GPIO function
        implement it before using Gpio
    get_level(self)
        Returns the level of the pin for input direction
        or return setting of the DR register for output gpios.
    set_dir(self, dir)
        set GPIO direction
        :dir: refer to GpioDir
    set_drv(self, drv)
        set GPIO drv
        :drv: refer to GpioDrv
    set_level(self, level)
        set GPIO output signal
        :level: refer to GpioLevel
    set_mux(self, mux)
        set GPIO mux
        :mux: refer to GpioMux
    set_pull(self, pull)
        set GPIO pull
        :pull: refer to GpioPull
Example for turn on/off the yellow led on firefly-rk3288:
  1.     $sudo python
  2.     >>> from fireflyP import Gpio
  3.     >>> Gpio.init()
  4.     >>> LED_YELLOW="GPIO8A2"
  5.     >>> led_yellow=Gpio(LED_YELLOW)
  6.     >>> led_yellow.set_dir(Gpio.OUTPUT) #set_dir have contained set_mux(GpioMux.MUX_GPIO)
  7.     >>> led_yellow.set_level(Gpio.LOW)  #turn on the yellow led
  8.     >>> led_yellow.set_level(Gpio.HIGH) #turn off the yellow led
Copy the code
or you can refer to demo/gpio_test.py
Pwm
Interface:
    init()
        Init PWM function
        implement it before using Pwm
    get_counter(self)
        Get PWM counter
    set_config(self, period, duty, config=10)
        set PWM period and duty.
        :period: ns
        :duty: ns
        :config: set PWMx_CTRL value except PWMx_CTRL.scale
    set_counter(self, counter)
        set PWM counter
    start(self)
        Start PWM
    stop(self)
        Stop PWM
Example for config pwm1(freq=1MHz,duty=50%):
  1.     $sudo python
  3.     >>> from fireflyP import Pwm
  4.     >>> Gpio.init()
  5.     >>> g7a1=Gpio('GPIO7A1')
  6.     >>> g7a1.set_mux(1)         #set GPIO7A1 mux to pwm1
  7.     >>> Pwm.init()
  8.     >>> pwm=Pwm('PWM1')
  9.     >>> pwm.set_config(1000,500)
  10.     >>> pwm.start()
  11.     >>> pwm.stop()
Copy the code
or you can refer to demo/pwm_test.py
Spi
Spi in fireflyP is depend on spidev,make sure your kernel support spidev(like this patch) or you can down the ready-made firmware([Google drive],[Baidu]).
The Spi source is modifed from python-spi (Thanks to Thomas).
Interface:
    read(self, length, speed=0, bits_per_word=0, delay=0)
        Perform half-duplex Spi read as a binary string
        Args:
            length: Integer count of words to read
            speed: Optional temporary bitrate override in Hz. 0 (default)
                uses existing spidev speed setting.
            bits_per_word: Optional temporary bits_per_word override. 0
                (default) will use the current bits_per_word setting.
            delay: Optional delay in usecs between sending the last bit and
                deselecting the chip select line. 0 (default) for no delay.
        Returns:
            List of words read from device
    transfer(self, data, speed=0, bits_per_word=0, delay=0)
        Perform full-duplex Spi transfer
        Args:
            data: List of words to transmit
        Returns:
            List of words read from Spi bus during transfer
    write(self, data, speed=0, bits_per_word=0, delay=0)
        Perform half-duplex Spi write.
        Args:
            data: List of words to write
Example for config spi0:
  1.     $sudo python
  2.     >>> from fireflyP import Spi
  3.     >>> spi = Spi('/dev/spidev0.0')
  4.     >>> spi.mode = Spi.MODE_3
  5.     >>> spi.bits_per_word = 8
  6.     >>> spi.speed = 1000*1000
  7.     >>> received = spi.transfer([0x11, 0x22, 0xFF])
  8.     >>> spi.write([0x12, 0x34, 0xAB, 0xCD])
  9.     >>> received = spi.read(10)
Copy the code
or you can refer to demo/spi_test.py, it is a example of lighting up a oled.
More project information refer to github.
Posted at 1/11/2026 06:51:35        Only Author  2#
I sincerely thank you for sharing this heart-shaking article! About to take the Latest E_S4CON_2505 guide files exam! Lets hope everything goes smoothly!
Posted at 1/16/2026 05:01:47        Only Author  3#
This article is impressive beyond words, thank you for sharing it. Good luck on your exam! Here are the free C_BCSBS_2502 new test collection free study materials.
Posted at 1/24/2026 05:54:41        Only Author  4#
This article is simply exceptional, I appreciate you sharing it. Get the Valid Plat-Dev-201 exam questions pdf questions that helped me succeed in my careerfor free today!
Posted at 1/26/2026 18:37:33        Only Author  5#
The article is truly moving, thank you for sharing! Latest free PDII study guide is available to everyone for free, packed with content that can aid you.
restricted members
Posted at 1/29/2026 11:43:03        Only Author  6#
Without thinking, Im liking this amazing content. Im giving you free access to the SC-100 real testing environment questions that led to my promotion and salary increase!
Posted at 2/24/2026 01:55:24        Only Author  7#
Ϥޤޤԇ롢픵ˤʤɡ̼Τʤˉ仯⤿餷ޤʤҡṩ|ߤSalesforceAP-208}ʹäơԇY˲μӤޤ⤷o¤AP-208ԇY˺ϸ񤷤顢ʤϤäŤˤʤäơʤšݤǤꤿȤ򤷤Ƥޤ
