Ambilight Project with Firefly RK3288
450
Posted at 9/14/2016 03:37:31      View6520 | Replies7        Print      Only Author   [Copy Link] 1#
Hi.
I'm requesting some help because i saw one internet one project called ambilight for arduino and other devices.
Is possible to impletmente that project with our RK3288 Firefly board?
I need help to know if its possible and sodoby with know how bluiding it to us!!!
So replys is very appreciated
Posted at 9/19/2016 22:36:48        Only Author  recommend
If it work in android with Ambilight plugin for kodi it would be great.
http://kodi.wiki/view/Ambient_lighting
For start it don't need the HDMI input, just analyze the screen out in android and controll the lights.
My problem is that i haven't sufficient know-how and i don't know how i can start this project.
We need enthusiasts for start this!! These will bring new life and competitive market in box market!!
Posted at 9/19/2016 02:39:41        Only Author  recommend
The Ubuntu 14.04/16.04 image created by the Firefly team does not support HDMI Input. So, unless you're ok with basing on Android, you'll need to modify the existing tc358743 driver (https://github.com/torvalds/linu ... edia/i2c/tc358743.c) to support tc358749. That would give you a /dev/video0 device which you can grab frames from using the video4linux2 API.
While firefly does have a tc358749 driver, to my understanding it's userspace and tied to the Android camera framework (along with a small kernel driver used to make the 'raw' device available in userspace). Perhaps something can be done with libhybris in order to use this driver on GNU/Linux?
1Prestige +10 Money +10 Contribution +10 Pack up reason
psycmos + 10 + 10 + 10
View all ratings
super moderator
Rank: 8Rank: 8
Posted at 9/14/2016 10:45:45        Only Author  recommend
That's interestingIt is great if somebody work on the project and to share
Reviews
Lets see if somebody will work on it!  Posted at 9/14/2016 15:12
Posted at 1/8/2026 16:03:34        Only Author  5#
Fast2test_V@úµPeoplecert ITIL-4-DITS}WYϣSrSصL҂WվҪĿ}҂ṩПTJCԇWYϣаPDFӰ汾ܛ汾ITIL-4-DITS}죬߀APPھ汾֧xʹã㿼xʹá҂ITIL-4-DITS}HԇпܳFІ}ITIL-4-DITSԇϸяYϣpͨ^yԇ
Posted at 1/9/2026 12:11:36        Only Author  6#
No hesitation, just hitting like for this great content. Im giving away the NCP-US-6.10 latest braindumps free test resources for free. Good luck!
Posted at 1/12/2026 10:06:36        Only Author  7#
ExamPassdump의IBM인증 C1000-189덤프공부가이드에는IBM인증 C1000-189시험의 가장 최신 시험문제의 기출문제와 예상문제가 정리되어 있어IBM인증 C1000-189시험을 패스하는데 좋은 동반자로 되어드립니다. IBM인증 C1000-189시험에서 떨어지는 경우IBM인증 C1000-189덤프비용전액 환불신청을 할수 있기에 보장성이 있습니다.시험적중율이 떨어지는 경우 덤프를 빌려 공부한 것과 같기에 부담없이 덤프를 구매하셔도 됩니다.
