New Topic
is RTC necessary for RK3288 / linux kernel?
66
Posted at 10/30/2016 04:28:21      View:6273 | Replies:11        Print      Only Author   [Copy Link] 1#
Hi All
Is the RTC circuit in firefly rk3288 reload board necessary? I am designing my own board using the reload core module and don't need accurate date or time. I also will not use the ethernet PHY or wifi / BT chips. Does the RK3288 need the RTC, or does the kernel need to RTC?
Thanks
B
super moderator
Rank: 8Rank: 8
Posted at 10/31/2016 09:58:13        Only Author  2#
Hi bschiett
in the core module ,the 3288 need a 32k clock which is supplied by RTC
whithout this ,the rk3288 have no the temparature protection.
and the other thing ,when  go to sleep ,the rk3288 change it's clock from 24M to this 32K.
so we suggest you to hold it .
Posted at 11/2/2016 05:01:49        Only Author  3#
isle Posted at 10/31/2016 09:58
Hi bschiett
thanks - in our application we don't want the linux kernel or rk3288 to sleep, we want it to keep running the same way non stop because it's an industrial application. How does the rk3288 use the 32k clock for temperature protection?
super moderator
Rank: 8Rank: 8
Posted at 11/2/2016 09:56:57        Only Author  4#
Hi bschiett
here :
please refer to the chapter of CRU :
http://bbs.t-firefly.com/forum.p ... =275&extra=page%3D1
Posted at 11/2/2016 16:59:12        Only Author  5#
OK, thanks so much for the clarification. Does the RTC need to be powered all the time and does it have to be able to wake the CPU? In other words in the reload schematic there is the possibility to attach a battery and the RTC has the possibility to turn the PWR_EN signal on, is this necessary or not for our application?
Screen Shot 2016-11-02 at 09.58.58.png (40.54 KB, Down times: 825)
Screen Shot 2016-11-02 at 09.59.02.png (67.36 KB, Down times: 843)
super moderator
Rank: 8Rank: 8
Posted at 11/3/2016 09:53:48        Only Author  6#
Hi bschiett
the battery is not necessary.
It need to  be attached only if you want  the CPU to be started automatically .
Posted at 11/4/2016 18:12:20        Only Author  7#
isle Posted at 11/3/2016 09:53
Hi bschiett
It need to  be attached only if you want  the CPU to b ...
Thanks, so the 2nd circuit above to turn on PWR_EN via RTC is not essential?
If the MCU section of the schematic is removed because we don't need IR, this means PWR_EN_SYS will not be pulled high (because there is no MCU_VCC), so basically when the power is plugged in (VCC_SYS present) the user will have to press the POWER switch (SW3) to boot the system, correct? And to switch it off again press the POWER switch?
super moderator
Rank: 8Rank: 8
Posted at 11/7/2016 10:22:26        Only Author  8#
Hi bschiett
Yes,It is not necessary.
Yes, when the MCU is gone,you can boot the system by press the POWER key.
Posted at 1/20/2026 10:19:42        Only Author  9#
Clicking the like button immediately—this is brilliant. The Exam Analytics-DA-201 price exam is here – wish me luck!
Posted at 2/1/2026 04:42:33        Only Author  10#
通過AP-211考試認證,如同通過其他世界知名認證,得到國際的承認及接受,AP-211考試認證也有其廣泛的IT認證,世界各地的人們都喜歡選擇AP-211考試認證,使自己的職業生涯更加強化與成功,在KaoGuTi,你可以選擇適合你學習能力的產品。
Return to List
12
