Not initialized SD-card in FIREDUINO
42
Posted at 1/2/2017 15:02:36      View:4206 | Replies:5        Print      Only Author   [Copy Link] 1#
Not initialized SD-card in FIREDUINO. If we use your examples of FIREDUINO TF WIKI read-write or playback AUDIO from SD cards which are normally visible on different ARDUINO Board not initialized on FIREDUINO - all stops to TF begin() . You need a special card or your library not working ?
Posted at 1/17/2017 21:11:52        Only Author  2#
The SD works. You need to format it before inserting it. I use https://www.sdcard.org/downloads/formatter_4/ from the SD Card Association. It's free.
Posted at 2/7/2017 18:13:14        Only Author  3#
I formatted the card , and it is perfectly readable at Arduino and Windows - but not in Fireduino . By the way your link is not working.
Posted at 3/15/2017 18:54:31        Only Author  4#
keemal Posted at 2/7/2017 18:13
I formatted the card , and it is perfectly readable at Arduino and Windows - but not in Fireduino .  ...
You need to copy the link text and past it into the browser. The forum changes the link to point nowhere.
Posted at 3/27/2017 19:27:03        Only Author  5#
ShaunPrice1 Posted at 3/15/2017 18:54
You need to copy the link text and past it into the browser. The forum changes the link to point n ...
Downloaded , formatted - no result ! I think I have a faulty device , since no sketch AUDIO also not working, hangs !
Posted at 5/17/2017 03:06:59        Only Author  6#
keemal Posted at 3/27/2017 19:27
Downloaded , formatted - no result ! I think I have a faulty device , since no sketch AUDIO also n ...
Hi. I have the same problem. I bought another fireduino plate but I have the same problem. He intentado con tarjetas SD de 1 GB, 2 GB, 8 GB y 16 GB. Please help. Do you sell defective board? Can you give me back my money?
