RK3399 linux - error no firefly_linux branch
Posted at 1/19/2017 17:44:20
Hi Firefly,
I want to experiment with the RK3399 linux kernel. I've followed the "build android" wiki in order to download the linux kernel sources up to the "git pull bitbucket master:master" command. And then I go to the kernel folder and type "git checkout firefly_linux". This command fails because there's no firefly_linux branch.
Could you check this on your side?
Also could you provide a "RK3399 linux only" git repo as you did for the RK3288 kernel?
And finally, wiki page "build android" refers to the SDK "firefly-rk3288_android4.4_git_20141211.tar.gz. Is it really the RK3288 archive which contains RK3399 stuff?
Sometimes ago Isle posted me a link to a 4.4 kernel:
This repo does not seem to be well alive, the last commit on branch tchip dates Oct 9, 2016. Is it really the linux kernel that'll be installed on your coming kickstarter firefly-rk3399 board ?
Thanks.
