New Topic
Full resolution firmware for OV13850
60
Posted at 2/14/2017 22:33:38      View:10156 | Replies:15        Print      Only Author   [Copy Link] 1#
Hello,
I am building a system with RK3288 and OV13850.
As reading the source code for the Lollipop I was wondering two things :
- what is the highest resolution I can handle (I don't see full resolution in the Hal code)
- is the Camera v2 API implementation level FULL or only LEGACY or LIMITED.
Thank you very much
super moderator
Rank: 8Rank: 8
Posted at 2/15/2017 15:08:16        Only Author  2#
Hi renaud,
1 Yes ,the OV13850 highest resolution "4224X3136" can be handled ,
the code is here : ./hardware/rockchip/camera/SiliconImage/isi/drv/OV13850/calib/OV13850.xml
  2 yes, the Camera V2 API is implemented fully.
Posted at 3/26/2017 13:39:36        Only Author  3#
Hi all,
What is best frame rate it can support?
super moderator
Rank: 8Rank: 8
Posted at 3/27/2017 10:02:25        Only Author  4#
we only test 1080P 30fps for recording
Posted at 3/27/2017 10:27:07        Only Author  5#
Hi isle,
How about 720p, can it reach 60 fps?
I have 2 version of OV13850 module with K and H. What is diffirent between them?
super moderator
Rank: 8Rank: 8
Posted at 3/27/2017 16:54:03        Only Author  6#
Hi
It should can reach 60fps,But we did test it yet.
about the K & H
the circuit board was made by two different factories ,and  There's no other difference.
Posted at 3/28/2017 11:10:54        Only Author  7#
Hi isle,
Which system do you use for testing 1080P 30fps?
I'm using Android 4.4, it only reach maximum 15 fps with 720p
super moderator
Rank: 8Rank: 8
Posted at 3/28/2017 11:47:17        Only Author  8#
the latest  Android 5.1 firmware.
Posted at 8/30/2017 05:04:26        Only Author  9#
isle Posted at 2/15/2017 15:08
Hi renaud,
the code is here : ...
Hi Isle,
Sorry for replying so late. I think I got not notification to tell me about your answer !
This is very good news. I am investigating right now to understand why the APK I use for testing Camera 2 level is returning Legacy. Maybe my firmware it is not configured correctly !
Would you mind having a look at our repository on Gitlab and tell us if you see something wrong ? Can we talk by email or by phone ?
Thank you very much !
super moderator
Rank: 8Rank: 8
Posted at 8/30/2017 09:51:38        Only Author  10#
hi
Have you try the firefly's repository on Gitlab?
Return to List
12
