New Topic
Power button is unuseful
25
Posted at 2/17/2017 16:20:39      View:11552 | Replies:15        Print      Only Author   [Copy Link] 1#
When I push power button, nothing happen.
I can turn on this board only after push the power adaptor after pull the power adaptor.
This power button had problem?
super moderator
Rank: 8Rank: 8
Posted at 2/18/2017 09:42:39        Only Author  2#
the power button is design for sleep/wake the system(like android),
and the reset button is design for reboot the board,
I'm not quiet sure about your question,
So ,what is your problem? Could you supply more informations?
Posted at 2/22/2017 14:18:57        Only Author  3#
isle Posted at 2/18/2017 09:42
and the reset button is design  ...
when my board is in shut down.
I press power button. then, nothing happen.
but, I plug out usb port and then plug in usb port. then board  boot successfully.
Posted at 2/23/2017 11:28:39        Only Author  4#
super moderator
Rank: 8Rank: 8
Posted at 2/23/2017 15:44:27        Only Author  5#
Hi
did you have anther board? if yes,did it has the same problem?
Which board did you have . the firefly-rk3288 or firefly-rk3288 reload?
and,which firmware did you use?
Posted at 2/23/2017 16:41:05        Only Author  6#
isle Posted at 2/23/2017 15:44
Hi
Which board did you have . the  ...
I have only one board.
What is the difference the firefly-rk3288 and firefly-rk3288 reload?
How can i find firmware version?
super moderator
Rank: 8Rank: 8
Posted at 2/24/2017 09:43:46        Only Author  7#
this is the firefly-rk3288:
http://shop.t-firefly.com/goods.php?id=5
and this is the firefly-rk3288 reload :
http://shop.t-firefly.com/goods.php?id=1
please check which one do you have.
which system do you have on your board? ubuntu or android?
Posted at 2/24/2017 11:30:25        Only Author  8#
isle Posted at 2/24/2017 09:43
and this is the firefly-rk328 ...
My board is firefly-rk3288.
I use this board in ubuntu.
I think power button is not work.
Posted at 2/24/2017 11:35:43        Only Author  9#
Posted at 2/24/2017 12:27:48        Only Author  10#
Return to List
12
