RK3399 SDK - Improvements needed from RK, Firefly
Posted at 3/4/2017 23:05:43
View5079
Replies7
Hi
I saw some bugs in the RK3399 SDK.
It is also present in other Rockchip MM SDK's but not in Lollipop.
I hope Firefly can report it to them to get fixed in the future.
There is no hide navigation bar setting or icon, so it doesn't hide.
RKBoxVideoPlayer can't play in fullscreen, it hides behind the navigation bar.
Pass-through sound code is missing in the SDK so won't work, I don't know why RK didn't fix it in Marshmallow? Luckily it is easy to fix and I can help.
Marshmallow also has no sound menu, maybe it can be added to change the output sound device.
Also remove the battery icon and tablet references, can be changed to 'device' instead.
Please check if the recovery menu will work and don't turn a green color after 15 seconds, it was a problem in other RK SDK's, but I think that might be fixed now.
Also add Fireasy support again.
Can add new RK3399 subforum to the forum.
RK3399 SDK, it would be nice to see previous commits, so if more bugs are identified, can easily see what code is effected or see how an improvement was made.
Regards |
