New Topic
Graphics & video acceleration for firefly-rk3399 in ubuntu
1821
super moderator
Rank: 8Rank: 8
Posted at 3/27/2017 10:44:55      View:9338 | Replies:11        Print      Only Author   [Copy Link] 1#
New ubuntu firmware for firefly-rk3399 (Beta version):
Graphics test:
  1. sudo apt install glmark2-es2
  2. glmark2-es2
Copy the code
video test :
  1. test_dec-gst.sh
Copy the code
dowload from here:
baidu:  https://pan.baidu.com/s/1qXFzhik
google:  https://drive.google.com/file/d/ ... Ws/view?usp=sharing
add opencl :
baidu  : http://pan.baidu.com/s/1jISdOZO
google: https://drive.google.com/file/d/ ... kU/view?usp=sharing
Posted at 4/2/2017 14:18:44        Only Author  2#
"Firefly-rk3399_xubuntu1604_201703241137_Beta.img" will not flash using any tool I use
super moderator
Rank: 8Rank: 8
Posted at 4/6/2017 10:12:31        Only Author  3#
what i use is the windows tool at the version 2.38.
Posted at 4/18/2017 22:53:36        Only Author  4#
Installed the OpenCL image from the link above  - it works!
  1. Platform ID: 0
  2. Device ID: 0
  3. Device: Mali-T860
  4. Vendor: ARM
  5. Hardware (device) version: OpenCL 1.2 v1.r13p0-00rel0-git(a4271c9).1ad3fc5b648bfed782705ad469a9797a
  6. Software (driver) version: 1.2
  7. OpenCL C version: OpenCL C 1.2 v1.r13p0-00rel0-git(a4271c9).1ad3fc5b648bfed782705ad469a9797a
  8. Address bits: 64
  9. Parallel compute units: 4
Copy the code
Posted at 4/20/2017 17:01:12        Only Author  5#
in gl2mark2 it has lower results than MIQI rk3288 board with 4.11 kernel
for example terrain on miqi 20fps and on rk3399 only 13 fps.
and now it lacks of vsync.
super moderator
Rank: 8Rank: 8
Posted at 4/20/2017 17:13:32        Only Author  6#
If you want get the score of the GPU performance. you need use the command "glmark2-es2 --off-screen"
because the  limitation is the X11 driver. not the mali GPU.
Posted at 4/20/2017 20:32:32        Only Author  7#
Hi isle,
How did you run the OpenCL demo?
super moderator
Rank: 8Rank: 8
Posted at 4/21/2017 14:32:14        Only Author  8#
Posted at 4/21/2017 17:57:25        Only Author  9#
So if you'll upgrade kernel to 4.11 with this guy patches https://github.com/Miouyouyou/MyyQi
you've got higher results + VSYNC
--off-screen is not intrested because everyone wants to have fast desktop for everyday usage.
Posted at 5/30/2017 14:33:02        Only Author  10#
I notice you mentioned video acceleration in the title.  Is there any support for hardware h.264 encoding or decoding yet on the command line, with e.g. ffmpeg?
Return to List
12
