Monitoring CPU temperature and clock speeds
176
Posted at 3/29/2017 15:42:20      View:6680 | Replies:9        Print      Only Author   [Copy Link] 1#
Hi,
Would it be possible to get some information regarding how to monitor CPU temperature and clock speeds of the RK3399 running Ubuntu?  The usual lm_sensors solution doesn't seem to work.
Thanks,
-Karl
Posted at 4/1/2017 02:17:09        Only Author  2#
Found what I needed:
  1. cat /sys/devices/system/cpu/cpufreq/policy?/cpuinfo_cur_freq /sys/devices/virtual/thermal/thermal_zone?/temp
Copy the code
I'm assuming that thermal_zone0 is the CPU.  thermal_zone2 looks like it's in different units, and perhaps not connected to anything.  Any clues as to what thermal_zone1 is?
super moderator
Rank: 8Rank: 8
Posted at 4/5/2017 10:20:03        Only Author  3#
0 for cpu, 1 for gpu.
super moderator
Rank: 8Rank: 8
Posted at 4/5/2017 10:22:45        Only Author  4#
cat   type
Posted at 1/10/2026 19:04:20        Only Author  5#
Through reading this article, I feel that I have made great progress. The Test C_THR94_2505 testking study materials are available for free—good luck!
Posted at 1/10/2026 22:39:35        Only Author  6#
This is a stellar article, thank you for sharing it with us. You can enjoy the CPT learning materials content for free, and it’s of high quality.
Posted at 1/12/2026 23:24:49        Only Author  7#
Thank you for your powerful article, it made a deep impression. Strengthen your IT skills with free DAA-C01 test experience. Best of luck in your preparations!
Posted at 1/19/2026 01:54:37        Only Author  8#
I truly appreciate your article; the content really left me in awe! The New CDCS exam testking questions are essential for your promotion and salary increase—free now!
Posted at 1/20/2026 19:39:20        Only Author  9#
只為成功找方法,不為失敗找藉口。想要通過EXIN的PR2F考試認證其實也沒有那麼難,關鍵在於你用什麼樣的方式方法。選擇NewDumps EXIN的PR2F考試培訓資料是個不錯選擇,它會幫助我們順利通過考試,這也是通往成功的最佳捷徑,每個人都有可能成功,關鍵在於選擇。
Posted at 1/30/2026 13:07:48        Only Author  10#
JpexamはThe Open GroupのOGEA-102認定試験に対して問題集を提供しておるサイトで、現場のThe Open GroupのOGEA-102試験問題と模擬試験問題集を含みます。ほかのホームページに弊社みたいな問題集を見れば、あとでみ続けて、弊社の商品を盗作することとよくわかります。Jpexamが提供した資料は最も全面的で、しかも更新の最も速いです。
