[Issue] Graphics Corruption, will not boot.
Posted at 4/4/2017 05:28:30      View:3385 | Replies:4        Print      Only Author   [Copy Link] 1#
I have noticed that from time to time, the RK3399 will show distorted/corrupted graphics. Once device is reset, it is not function for some time. Attempt various workaround, multiple power cycle, disconnect all connectors but power, manual MASKROM flash boot, never obtain loader.
I have no logs
Posted at 4/4/2017 08:31:08        Only Author  2#
I discovered that my board has a physical issue. Heat/cold affected functionality. Later I discovered that applying slight pressure to the Rockchip restores functionality. Bad solder joints? broken traces? not sure. In the case of bad solder joints, can't i just take a heat gun to the board? or will that cook/damage the board?
super moderator
Rank: 8Rank: 8
Posted at 4/6/2017 09:51:23        Only Author  3#
you can take a heat gun to the board,but don't pressure anything,
if have no improvement, please send the board to us ,and we will repare it .
Posted at 4/6/2017 11:55:36        Only Author  4#
I will try, what about shipping?
super moderator
Rank: 8Rank: 8
Posted at 4/6/2017 17:37:17        Only Author  5#
please connect Customer service : skype:791191114@qq.com
