New Topic
[Issue] Stock Recovery RK3399 & ADB not function.
Posted at 4/4/2017 08:35:16      View:7579 | Replies:13        Print      Only Author   [Copy Link] 1#
When going into the Stock recovery on the Firefly-RK3399, ADB functions do not work.
Posted at 4/5/2017 10:40:33        Only Author  2#
try to link a sh for adb in recovery.
out/target/product/rk3399_firefly_box/recovery/root/
ln -sf /sbin/sh  system/bin/
rebuild recovery.img and flash it , retry
Posted at 4/6/2017 01:28:20        Only Author  3#
ok, so I extract recovery.img, then extract ramdisk.gz, now I symlink system/bin/sh to /sbin/sh ?
Posted at 4/6/2017 09:58:52        Only Author  4#
BiatuAutMiahn Posted at 4/6/2017 01:28
It maybe work, I sugguest you do it under the SDK .
Posted at 4/6/2017 11:55:00        Only Author  5#
ok, thank you
Posted at 6/25/2018 17:33:26        Only Author  6#
Hello!
I did this ("ln -sf /sbin/sh  system/bin/ " in "out/target/product/rk3399_firefly_aio_box/recovery/root/" under SDK, then recompile and reflash recovery.img)
But ADB in recovery mode still doesn't work. I can't see any usb devices on my PC for AIO on recovery mode (I'm using linux PC and I'm sure 100%)
What should I do next?
Posted at 6/27/2018 10:47:28        Only Author  7#
sol Posted at 6/25/2018 17:33
Hello!
I did this ("ln -sf /sbin/sh  system/bin/ " in "out/target/product/rk3399_firefly_aio_box/ ...
No need to complie , just pack it up after complie the whole SDK.
Run ./mkimage.sh and get the recovery.img .
Flash recovery.img and it will be work.
Posted at 6/28/2018 19:51:42        Only Author  8#
leung先森 Posted at 6/27/2018 10:47
Run ./mkimage.sh and get the re ...
Ok, to check everything I did all from scratch:
1. Download fresh SDK (Firefly-RK3399_Android7.1.2_git_20180126.7z)
2. Unzip it, updated it (git pull gitlab firefly-rk3399:firefly-rk3399 - everything up to date)
3. Compiled it with ./FFTools/make.sh -j8  -l rk3399_firefly_aio_box-userdebug
4. Ru "ln -sf /sbin/sh  system/bin/ " in "out/target/product/rk3399_firefly_aio_box/recovery/root/"
5. Run "/mkimage.sh", new recovery.img was made
6. Flashed this new recovery.img with rkflashkit to recovery partition
6. After board boot, run "adb reboot recovery" on my PC
7. When board boots into recovery, I can see that this recovery image is new (date and time is written at the top of menu).
But result of "adb devices" on my PC is empty! I can't run "adb sideload" or anything else.
And there no unknown devices in "lsusb" output on my PC.
Also, if I select "Apply update from ADB" from recovery menu - I see error "Failed to open driver control: No such file or directory"
So, in recovery mode ADB not working with or without selecting "Apply update from ADB" in recovery menu.
This is a screenshot from /cache/recovery/last.kmsg:
https://www.dropbox.com/s/m4ya7h ... 628_144740.jpg?dl=0
It shows "init: avc: denied {set} for property=sys.usb.ffd.ready" before "init: Starting service adbd", maybe this is the reason why ADB doesn't work?
Please help!
Posted at 6/29/2018 09:27:13        Only Author  9#
sol Posted at 6/28/2018 19:51
1. Download fresh SDK (Firefly-RK3399_Android7.1. ...
You need to make sure that when you run ./mkimage.sh is "lunch rk3399_firefly_aio_box" .
As I kown , if you do not lunch by hand , it default lunch rk3399_firefly_box insteal of  rk3399_firefly_aio_box.
Posted at 6/29/2018 17:35:52        Only Author  10#
leung先森 Posted at 6/29/2018 09:27
As I kow ...
Yes, I did lunch by hand with "lunch rk3399_firefly_aio_box"
My recovery image title is "rockchip/rk3399_firefly_aio_box/rk3399_firefly_aio_box 7.1.2/NHG47K/...", so it's for firefly_aio_box
But ADB USB connection is not working in this revovery mode (with "ln -sf /sbin/sh  system/bin/")
Maybe you can post your recovery.img with working ADB for firefly_aio_box somewhere (i.e. on your gitlab)?
Your advice "ln -sf /sbin/sh  system/bin/ " doesn't affect ADB functionality in recovery mode.
Please help.
P.S. Also I  can't use "Apply update from SD card" from recovery menu, it gives "E:failed to map file"
Return to List
12
