Ubuntu16.04, Kernel, and Boot image Issues
Posted at 4/6/2017 08:37:28
Hello Firefly community,
I am running to some issues getting the boot image that I compiled from the firefly github repository on a host machine running Ubuntu 14.04 to work on the rk3288 firefly dev board.
I am able to compile the latest kernel by following the instructions provided at http://wiki.t-firefly.com/index. ... 288/Build_kernel/en. I am also able to build the Initramfs and build the boot image. However, when I flash the boot.img via rkflashtool to the boot partition, the board will always just have a blank screen. I have been trying different rockchip_linux defconfigs and did not get any different outcome.
Have anyone who attempted to build their own kernel and Ubuntu images ran into a similar issue? Or maybe you did things differently from what the firefly team suggests and got a working image.
For reference, I am using the following source code:
- kernel_4.4 (firefly-rk3288 branch): https://github.com/T-Firefly/kernel_4.4
- initrd (for-kernel_4.4 branch): https://github.com/T-Firefly/initrd/tree/for-kernel_4.4
On a side note, once I get a working kernel and boot image, I plan to port the mali kernel driver r12p0 released by ARM. This is because the current mali driver is r9 and I am hoping to improve my performance with OpenGL ES with the newer gpu driver.
Any help would be appreciated. Thanks! |
