New Topic
[Root] SuperSU USB ADB Installer RK3399
Posted at 4/7/2017 08:10:43      View:14315 | Replies:11        Print      Only Author   [Copy Link] 1#
Hello, today I have created an Install script for SuperSU via USB ADB.
Simply run script SuRoot.exe and device will reboot when process has finished.
Source included for inspection.
Download:
<snip> See my last Post
super moderator
Rank: 8Rank: 8
Posted at 4/7/2017 09:35:43        Only Author  2#
good
Posted at 4/7/2017 14:44:50        Only Author  3#
Thank you
Posted at 6/14/2017 14:45:45        Only Author  4#
Hi,
It seems that's not work with Nougat, the board is blocked at android screen.
Have you tested it on Nougat ?
cheers
Posted at 7/22/2017 01:46:53        Only Author  5#
No, not tested with Nougat, sorry.
Posted at 8/22/2017 08:05:44        Only Author  6#
What operating system are you running the script on because my adb doesn't recognise any devices plugged into it.
Posted at 3/3/2022 12:23:37        Only Author  7#
This script has not been updated since 2017 is not guaranteed to work. When making this script I simply follow the script in the SuperSU install script and did the equivalent commands via ADB.
At some point I may write a wrapper that will interpret a flashable ZIP and install it via adb.
Posted at 3/3/2022 12:28:03        Only Author  8#
Here is updated link for my firefly folder in Google Drive. Again, this content is old and should only be considered for reference. Commenting is enabled. My firefly board ended up having broken traces in the PCB I think due to thermal stress, I abandoned the projects.
https://drive.google.com/drive/f ... aXg&usp=sharing
Posted at 1/12/2026 10:09:43        Only Author  9#
The content of the article is rich and profound, and I’ve learned a lot from it. The Latest Sales-Admn-202 learning materials resources are excellent, and there’s no cost to access them.
Posted at 1/17/2026 05:43:06        Only Author  10#
It gave me so many new insights to explore. SPP new study questions book questions shared for free—unlock promotions and salary increases!
Return to List
12
