more space for apps and root
4
Posted at 12/10/2014 19:32:55      View:4108 | Replies:3        Print      Only Author   [Copy Link] 1#
any chance of a android rom with 4gig of apps space, Play Store and rooted ?
I am a newbie...lol.....I've been playing with android tool 2.3 and managed to combine the firefly boot.img, kernel.img,resourses.img and misc.img with mo123's  HPHRK3288 rom v1.2 (  http://www.freaktab.com/showthread.php? ... -(20141117 )
and am playing around with it......seems to work mostly, but wifi slow.
Also tried FinlessBob's 3288 EZ Root Tool ( http://www.freaktab.com/showthread.php? ... -Root-Tool )....it works.
Posted at 12/11/2014 15:04:30        Only Author  2#
You just need a modified parameter file.
Whenever I have flashed RK3288 ROM's, I often place them into?RK3xxx_firmware_tools_5.10.28.00, which you can download here.
http://vondroid.com/threads/rk3xxx-firm ... ony.14718/
Within the interface, there is a parameter tool that allows you to modify the partition to whatever size you want it to be.
You can also extract system and boot images should you want to make modifications there too.
Then you can repack ready for flashing.
If you look at the first post here
http://www.freaktab.com/showthread.php? ... nsmart-R28
There are some root/unroot tools that you can apply which should work.
Posted at 12/11/2014 16:59:53        Only Author  3#
thanks...i'll check that out
Posted at 12/13/2014 18:39:59        Only Author  4#
I have also read a post from a Firefly users that uses this easy to use root option.
