New Topic
RK3399 M.2 SATA
24
RK3399 M.2 SATA
Posted at 4/11/2017 03:44:30      View:20240 | Replies:29        Print      Only Author   [Copy Link] 1#
I have installed an M.2 SATA 2242 SSD on my RK3399. It doesn't appear to show up at all under Linux - is there something I'm missing?
thanks
Posted at 4/11/2017 07:03:11        Only Author  2#
I have a similar problem: I've inserted a M.2 -> SATA converter [1] and attached a sata harddrive, but the drive is not showing up in Linux. I've looked at `lsblk` and `lspci` (the latter results in an error) with no luck.
[1]: http://www.microsatacables.com/m ... apter-ngff-b-m-7pin
Posted at 4/12/2017 11:00:42        Only Author  3#
i think I saw that the kernel needs to be configured for support in another thread
Posted at 4/12/2017 13:07:41        Only Author  4#
BiatuAutMiahn Posted at 4/12/2017 11:00
Do you have a link?
Posted at 4/14/2017 10:33:41        Only Author  5#
I just tried with the latest beta image: https://drive.google.com/drive/f ... gAqAN0hWd1FMN1Zjb0k
... still no dice.
Do I have to use the official adapter board? http://shop.t-firefly.com/goods.php?id=52
Or do I have to use a different kernel to get pci/m.2 support?
Posted at 4/19/2017 12:05:13        Only Author  6#
I have done some research, the kernel looks like it has PCI enabled in the config (how/if it's implemented I do not know) and I'm now leaning toward u-boot needing some configuration to use the PCIe bus. I have reached out to support but no reply from them at this time.
Posted at 4/19/2017 13:20:09        Only Author  7#
I did just get confirmation on the #linux-rockchip irc channel that someone has actually gotten pci working but not with the firefly. He pointed me to the https://github.com/rockchip-linux/kernel project and said the 4.4 kernel is what he used. He was also kind enough to show where in the device tree pci was defined https://github.com/rockchip-linux/kernel/blob/release-4.4/arch/arm64/boot/dts/rockchip/rk3399-firefly-linux.dts#L744  Now, last time I looked through the firefly SDK source and compiled a kernel I did notice that device tree was not enabled in the .config so unless I misunderstood something, the kernel will need to be compiled with device tree support to properly use the pci bus. This should include m.2 SSD devices also.
Posted at 4/27/2017 00:57:23        Only Author  8#
Is there actually SATA support on the M.2 slot or is it PCI-E only? Seems strange they made the decision to put the mini PCI-E port on the bottom instead of the M.2 (would have had space for a full size 2280 drive there). Problem here is that if there is no SATA support on the M.2 - you can't really find PCI-E drives in that form factor so you have to use an awkward adapter card.
Posted at 4/30/2017 11:16:24        Only Author  9#
I just tried again with the latest `Firefly-rk3399_xubuntu1604_201704271809` image - it still doesn't work...
super moderator
Rank: 8Rank: 8
Posted at 5/2/2017 19:22:58        Only Author  10#
Hi
did you get the "/dev/block/nvme0n1p1" when insert your pci-e devices.?
Return to List
1234
