sdhci-arasan fe330000.sdhci: data error (-84)
84
Posted at 4/22/2017 01:15:44      View:6527 | Replies:6        Print      Only Author   [Copy Link] 1#
hi my friends ,my mini pc not work .all detail about this is written below .plz
1.696309] sdhci-arasan fe330000.sdhci: data error (-84)
[    1.696362] sdhci-arasan fe330000.sdhci: failed (-84) to handle RPMB request
super moderator
Rank: 8Rank: 8
Posted at 4/24/2017 15:53:26        Only Author  2#
what is your miniPC ,is a rk3399 board made by yourself?
Posted at 4/24/2017 17:40:14        Only Author  3#
It look like something wrong with eMMC .
You can try the new Firmware. Or wait the SDK update,
I heard this week will update 3399 source code .
Posted at 8/26/2017 06:42:07        Only Author  4#
I received my rk3399 board few days ago an I got same problem, I tried Android and flint_os. On flint_os I got kernel panic, on Ubuntu it's stuck on this:
[    1.665824] sdhci-arasan fe330000.sdhci: data error (-84)
[    1.666364] sdhci-arasan fe330000.sdhci: failed (-84) to handle RPMB request
u?   1.675940]
[    1.730858] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    1.752497] dwmmc_rockchip fe310000.dwmmc: Successfully tuned phase to 317
[    1.760954] mmc2: queuing unknown CIS tuple 0x91 (3 bytes)
[    1.761539] mmc2: new ultra high speed SDR104 SDIO card at address 0001
any help?
Posted at 8/26/2017 07:10:00        Only Author  5#
And this is the output loading flint:
[    1.635925] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[    1.639277] mmcblk1: error -110 sending stop command, original cmd response 0x900, card status 0x400900
[    1.640196] mmcblk1: error -84 transferring data, sector 2602120, nr 32, cmd response 0x900, card status 0x0
[    1.641097] mmcblk1: retrying using single block read
[    1.651438] mmcblk1: error -84 transferring data, sector 2602147, nr 5, cmd response 0x900, card status 0x0
[    1.652317] blk_update_request: I/O error, dev mmcblk1, sector 2602147
[    1.655667] mmcblk1: error -84 transferring data, sector 2602148, nr 4, cmd response 0x900, card status 0x0
[    1.656658] blk_update_request: I/O error, dev mmcblk1, sector 2602148
[    1.660219] mmcblk1: error -84 transferring data, sector 2602150, nr 2, cmd response 0x900, card status 0x0
[    1.661148] blk_update_request: I/O error, dev mmcblk1, sector 2602150
[    1.666383] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[    1.669373] mmcblk1: error -110 sending stop command, original cmd response 0x900, card status 0x400900
[    1.670283] mmcblk1: error -84 transferring data, sector 1188736, nr 144, cmd response 0x900, card status 0x0
[    1.671246] mmcblk1: retrying using single block read
[    1.691750] mmcblk1: error -84 transferring data, sector 1188789, nr 91, cmd response 0x900, card status 0x0
[    1.692698] blk_update_request: I/O error, dev mmcblk1, sector 1188789
[    1.714908] mmc_host mmc2: Bus speed (slot 0) = 200000000Hz (slot req 208000000Hz, actual 200000000HZ div = 0)
[    1.723999] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[    1.726966] mmcblk1: error -110 sending stop command, original cmd response 0x900, card status 0x400900
[    1.727876] mmcblk1: error -84 transferring data, sector 3290496, nr 32, cmd response 0x900, card status 0x0
[    1.728797] mmcblk1: retrying using single block read
[    1.732799] mmcblk1: error -84 transferring data, sector 3290498, nr 30, cmd response 0x900, card status 0x0
[    1.733768] blk_update_request: I/O error, dev mmcblk1, sector 3290498
[    1.737489] mmcblk1: error -84 transferring data, sector 3290501, nr 27, cmd response 0x900, card status 0x0
[    1.738480] blk_update_request: I/O error, dev mmcblk1, sector 3290501
[    1.741644] mmcblk1: error -84 transferring data, sector 3290502, nr 26, cmd response 0x900, card status 0x0
[    1.742590] blk_update_request: I/O error, dev mmcblk1, sector 3290502
[    1.745837] mmcblk1: error -84 transferring data, sector 3290503, nr 25, cmd response 0x900, card status 0x0
[    1.746782] blk_update_request: I/O error, dev mmcblk1, sector 3290503
[    1.750049] mmcblk1: error -84 transferring data, sector 3290504, nr 24, cmd response 0x900, card status 0x0
[    1.751002] blk_update_request: I/O error, dev mmcblk1, sector 3290504
[    1.759651] mmcblk1: error -84 transferring data, sector 3290519, nr 9, cmd response 0x900, card status 0x0
[    1.760588] blk_update_request: I/O error, dev mmcblk1, sector 3290519
[    1.763510] mmcblk1: error -84 transferring data, sector 3290520, nr 8, cmd response 0x900, card status 0x0
[    1.766667] mmcblk1: error -84 transferring data, sector 3290521, nr 7, cmd response 0x900, card status 0x0
[    1.771241] mmc1: Got data interrupt 0x00000002 even though no data operation was in progress.
[    1.774126] mmcblk1: error -110 sending stop command, original cmd response 0x900, card status 0x400900
[    1.774997] mmcblk1: error -84 transferring data, sector 3290496, nr 8, cmd response 0x900, card status 0x0
[    1.775869] mmcblk1: retrying using single block read
[    1.781227] mmcblk1: error -84 transferring data, sector 3290501, nr 3, cmd response 0x900, card status 0x0
[    1.784817] mmcblk1: error -84 transferring data, sector 3290503, nr 1, cmd response 0x900, card status 0x0
[    1.785930] Kernel panic - not syncing: Requested init /sbin/init failed (error -5).
[    1.786618] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.4.52 #21
[    1.787147] Hardware name: Rockchip RK3399 Firefly Board (Linux Opensource) (DT)
after that there is a long call trace
2Wan
hardcore
Rank: 8Rank: 8
Posted at 5/16/2018 18:08:49        Only Author  6#
nadsat Posted at 8/26/2017 07:10
[    1.635925] mmc1: Got data interrupt 0x00000002 even tho ...
Hello , I have met the same problem with you.
Have you solved it out ?
Thank you.
2Wan
hardcore
Rank: 8Rank: 8
Posted at 5/16/2018 20:12:50        Only Author  7#
I have solved this problem by decrease eMMC clk frequence from 200MHz to 150MHz.
maybe  there are some problems  about eMMC signal  on Hardware designing.
