Trouble flashing using AndroidTool 2.38
30
Posted at 4/30/2017 20:29:56      View:5393 | Replies:3        Print      Only Author   [Copy Link] 1#
I am having trouble flashing Ubuntu onto the 3399 using AndroidTool 2.38 running on Windows 10.
I am following the instructions as indicated on the wiki and receiving an error. The drivers seem to be installed correctly and the tool sees the 3399. It starts to run through the process of flashing, but then errors when it tries to actually perform the writing:
The wiki states to try low-level format if you get an error, but that produces an error as well:
Any help with this? Seems like it should just work...
Thanks,
Scott
super moderator
Rank: 8Rank: 8
Posted at 5/2/2017 19:46:52        Only Author  2#
Posted at 1/13/2026 10:38:17        Only Author  3#
This article is brilliant, and I’ve gained a lot of inspiration from it. Improve your IT skills with free Valid 300-215 real test. Wishing you the best of luck!
Posted at 1/17/2026 21:59:30        Only Author  4#
I’m utterly amazed by your article, thank you for sharing it! New SAE-C01 exam cram review offers a broad range of material free of charge, hoping it supports you.
