New Topic
Boot from SD on 3399?
30
Posted at 5/1/2017 22:46:04      View:16249 | Replies:19        Print      Only Author   [Copy Link] 1#
Is it possible to boot from SD card to get the install process going? I'm having trouble flashing the emmc and hoping to bypass that process and use a process I'm a little more familiar with.
Thanks,
Scott
super moderator
Rank: 8Rank: 8
Posted at 5/2/2017 19:28:19        Only Author  2#
Yes,it is possible.
we will release a firmware later.
Posted at 5/5/2017 05:49:13        Only Author  3#
isle Posted at 5/2/2017 19:28
Yes,it is possible.
Do you have a time frame when this will be released? We have an OS on microSD that would be great to run on the Firefly.
已有 1评分Prestige +10 Pack up reason
dennek + 10
View all ratings
super moderator
Rank: 8Rank: 8
Posted at 5/16/2017 09:59:59        Only Author  4#
find the "Firefly-rk3399_xubuntu1604_SD_201705151725.7z" file in our google driver.
Posted at 7/28/2017 12:03:17        Only Author  5#
I download Firefly-rk3399_xubuntu1604_SD_201705151725.7z and write to a sd card using window imagewriter.
However, I am not able to boot from sd. Booting after power reset is still from an internal flash memory
Posted at 7/28/2017 14:24:43        Only Author  6#
Do we have any board jumper or similar to setting up SD boot mode?
Posted at 7/28/2017 15:38:10        Only Author  7#
No. Which jumper ? Is there a documentation to describe jumper setting for SD boot?
Thanks,
Posted at 7/28/2017 21:03:18        Only Author  8#
Then How to use BOOT from SD, it's always booting from eMMC or any booting order?
super moderator
Rank: 8Rank: 8
Posted at 8/2/2017 10:02:07        Only Author  9#
if your emmc is not empty.your need flash our latest ubuntu firmware(without  SD symbol) into emmc.
Posted at 8/2/2017 22:14:18        Only Author  10#
I'm able to boot from eMMC..all works fine.. I need to boot the board from SDMMC..Please let me know how to do that?
Return to List
12
