Power button skip
13
Power button skip
Posted at 5/18/2017 15:40:44      View:3998 | Replies:3        Print      Only Author   [Copy Link] 1#
Hi,
I have Vsmart Q8 tvbox (3288) hardware with Android 5.1 built on basis of sources from respective firefly device , so it definitely should have similar hardware as firefly-3288. My problem is that I would like to use  TV box as car-pc and boot it directly after power on, without any use of power button or remote control. Is it possible? I've checked similar threads for Samsung tablets and phones and they use battery animation script to pass reboot command for this purpose. But in my case TV Box does not show any animations in sleep mode, so there should be something different to change.
Thank you,
Jevgenijs
super moderator
Rank: 8Rank: 8
Posted at 5/19/2017 10:00:14        Only Author  2#
It is need some  hardware modification.
Posted at 5/21/2017 06:46:43        Only Author  3#
You need hardware modification. Replace power button with  this piece.
It will detect when you have energy ON and shotcut the power button. Cheers
Posted at 5/28/2017 23:45:31        Only Author  4#
Hmm, won't relay switch board off if it will keep close and not release "button" for some time?
