RK 3288 Reload 4K/1440p output/input questions
101
Posted at 6/14/2017 19:25:34      View:4402 | Replies:4        Print      Only Author   [Copy Link] 1#
Hello, I want to know 2 things:
1) If I connect a 2560x1440p or a 4K monitor to firefly RK 3288 Reload, I can see maximum 1080p resolution in android settings. I cant set it to higher?
2) Can the HDMI INPUT recieve and display 4K video? or for HDMI INPUT is it's max 1080p.
I read on forum that for 4k I need to dsiable dual display.. can anyone tell me how to do it? do I need to build kernel or trhere is a ready firmware for this. If it's possible can you make a custom firmware witrh dual display diasbled and put on the google cloud? would help very much.
thanks!
super moderator
Rank: 8Rank: 8
Posted at 6/15/2017 10:03:48        Only Author  2#
Hi
1 the max resolution of  HDMI IN is 1080P.
2 4K display , there is no such a firmware for you , you need rebuild the kernel with the modification like this:
diff --git a/kernel/arch/arm/boot/dts/firefly-rk3288-reload.dts b/kernel/arch/arm/boot/dts/firefly-rk3288-reload.dts
index 2159526..1a428b5 100644
--- a/kernel/arch/arm/boot/dts/firefly-rk3288-reload.dts
+++ b/kernel/arch/arm/boot/dts/firefly-rk3288-reload.dts
@@ -187,7 +187,7 @@
         hpd-gpio = <&gpio4 GPIO_D3 GPIO_ACTIVE_HIGH>;
                rockchip,source = <0>; //0: LCDC0; 1: LCDC1
                rockchip,prop = <PRMRY>;//<PRMRY>;//<EXTEND>
-               status = "okay";
+               status = "disabled";
Posted at 6/15/2017 16:54:41        Only Author  3#
Isle, thanks for sharing the firmware for it in the other thread!
Are there any plans to release a firefly like the RK3288 Reload with 4K HDMI INPUT?
In general , If I need to connecct a 4K video camera to the HDMI INPUT, and send it to OUTPUT, is there any android box solution sold today that will allow me to do it?
I would order it right away.
Posted at 6/15/2017 17:05:55        Only Author  4#
super moderator
Rank: 8Rank: 8
Posted at 6/16/2017 10:43:06        Only Author  5#
Sorry ,No plans.
