Request: FireFly Rk 3288 reload firmware with 4k support (NO dual display)
101
Posted at 6/15/2017 00:22:17      View:4376 | Replies:6        Print      Only Author   [Copy Link] 1#
Hello. I need the latest android firmware for the RK 3288 reload with 4k resolution support and dual display disabled. after arch/arm/boot/dts/firefly-rk3288-reload.dts had been changed to make it work with 4k etc..
I dont have a linux box and I can't build it myself.
Would greatly appreciate if anyone could build this version for me and post it. I'm sure more people will want it to use 4K.
thanks!@
super moderator
Rank: 8Rank: 8
Posted at 6/15/2017 10:16:41        Only Author  2#
Oh~~~~~
there is similar requested firmware we have made,  I will put it to the gd later,
super moderator
Rank: 8Rank: 8
Posted at 6/15/2017 10:24:57        Only Author  3#
Posted at 6/15/2017 17:29:45        Only Author  4#
Hello Isle
what is pcba_whole and pcba_small image inside the image directory? I didn't  know what to do with them.
I flashed this image (using download tab in android tool, i loaded all image files and click "Run") but still max 1080p when connected to a 2k monitor
any idea?
super moderator
Rank: 8Rank: 8
Posted at 6/16/2017 10:38:01        Only Author  5#
do you have another 2k monitor? my workmate told me, he have tested the 4K/2K function is ok to connect on his monitor.
Posted at 6/16/2017 15:24:32        Only Author  6#
isle Posted at 6/16/2017 10:38
do you have another 2k monitor? my workmate told me, he have tested the 4K/2K function is ok to conn ...
Isle, I just want to make sure I understand how to make it work
I connect the FireFly to the 2k or 4k monitor, and go to settings >display >? HDMI MODE
and should see the new resolution?
super moderator
Rank: 8Rank: 8
Posted at 6/16/2017 16:18:34        Only Author  7#
Yes, If the monitor has been recognized correctly(by read edid),the mode list should be seen in the HDMI MODE of display settting.
