Trying to compile android 6.0 image file
77
Posted at 6/18/2017 13:43:24      View:4094 | Replies:6        Print      Only Author   [Copy Link] 1#
Following this guide: http://wiki.t-firefly.com/index. ... 99/Build_android/en
when i run
  1. <pre>cd ~/proj/firefly-rk3399/
  2. ./FFTools/make.sh -j8</pre>
Copy the code
it gives me the following error and does not complete:
  1. clang: error: linker command failed with exit code 1 (use -v to see invocation)
  2. build/core/host_shared_library_internal.mk:51: recipe for target 'out/host/linux-x86/obj32/lib/libart.so' failed
  3. make: *** [out/host/linux-x86/obj32/lib/libart.so] Error 1
Copy the code
More of the output from compiler:
https://pastebin.com/GV25kPu2
As far as i can tell I am missing this libart.so file, however I have not made any changes since downloading the source code.
how do i fix this error?
super moderator
Rank: 8Rank: 8
Posted at 6/19/2017 10:07:40        Only Author  2#
did you  get the latest source code?
Posted at 6/21/2017 03:18:44        Only Author  3#
yes i have the latest source code,  I didn't establish the build environment correctly i must have missed a sudo somewhere and didn't notice it.
after going through https://source.android.com/source/initializing again it compiled correctly.
Posted at 1/16/2026 01:11:06        Only Author  4#
Your article is a masterpiece, thank you for sharing it! Best of luck with your exam preparation! ITIL-4-Foundation reliable study questions free download questions are free for you to use!
Posted at 1/16/2026 11:22:14        Only Author  5#
I sincerely thank you for sharing this impactful article! The Practice CMT-Level-I exam fee exam questions are available for free. Wishing you the best in your exams!
Posted at 2/3/2026 17:14:47        Only Author  6#
I’m in awe of your article, thank you for sharing! The Reliable Professional-Cloud-Security-Engineer dumps exam is coming up soon – hope I pass with ease!
Posted at 2/6/2026 19:21:53        Only Author  7#
What an exceptional article, I appreciate you sharing it! I’m about to take the Valid exam 156-561 topics pdf exam. Wish me good fortune!
