New Topic
Ubuntu image does not shutdown
83
Posted at 6/25/2017 16:59:20      View:6808 | Replies:16        Print      Only Author   [Copy Link] 1#
Attempting to shutdown the board causes it to reboot.  Is there a fix for this?  I can be reproduced by issuing the following command:
  1. sudo shutdown -h now
Copy the code
super moderator
Rank: 8Rank: 8
Posted at 6/27/2017 10:46:36        Only Author  2#
please  update the kernel/resource image by the latest source code
http://wiki.t-firefly.com/index. ... 399/Build_kernel/en
then try again.
Posted at 6/27/2017 22:51:19        Only Author  3#
Using the latest kernel, the problem remains.  The device reboots instead of powering down.
super moderator
Rank: 8Rank: 8
Posted at 6/28/2017 10:53:21        Only Author  4#
really? but, I have check it is power down,not reboot.
Posted at 6/28/2017 20:49:32        Only Author  5#
The issue occurs using the "Firefly-rk3399_xubuntu1604_201705111112.7z" image from download page:
https://drive.google.com/drive/f ... gAqAX2oyZkg2QVQwZjA
super moderator
Rank: 8Rank: 8
Posted at 6/29/2017 09:44:17        Only Author  6#
Did you have this issue when using the latest kernel  ?
Posted at 6/29/2017 10:37:29        Only Author  7#
Yes, the issue occurs using both the kernel in the image mentioned and the latest kernel compiled from source.
Posted at 6/29/2017 10:46:57        Only Author  8#
Is this uboot reversion related to the issue?
https://gitlab.com/TeeFirefly/ub ... 54c43cb8ae1a4823ee8
  1. Revert "plat: rk3399: add virtual poweroff support"
  2. Change-Id: I59231ba6280c0e4e89cf61704701c03a3a287c5e
  3. Signed-off-by: shengfei Xu <xsf@rock-chips.com>
Copy the code
Posted at 7/1/2017 22:10:35        Only Author  9#
I have the same issue. Now I just use
  1. sudo halt
Copy the code
Seems to be related to poweroff and ACPI stuff indeed...
Posted at 7/6/2017 02:45:08        Only Author  10#
The same issue here with Ubuntu - with latest kernel compiled from the source codes.
Return to List
12
