Missing CPU frequencies
83
Posted at 6/27/2017 01:58:01      View:3993 | Replies:4        Print      Only Author   [Copy Link] 1#
The top operating frequencies for both big and little cores appear to be missing:
  1. firefly@firefly:~$ cat /sys/devices/system/cpu/cpu4/cpufreq/scaling_available_frequencies
  2. 408000 600000 816000 1008000 1200000 1416000 1608000 1800000
  3. firefly@firefly:~$ cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies
  4. 408000 600000 816000 1008000 1200000 1416000
Copy the code
The device tree indicates the support here:
https://gitlab.com/TeeFirefly/li ... 9-opp.dtsi#L133-137
  1.                 opp@1992000000 {
  2.                         opp-hz = /bits/ 64 <1992000000>;
  3.                         opp-microvolt = <1225000>;
  4.                         clock-latency-ns = <40000>;
  5.                 };
Copy the code
https://gitlab.com/TeeFirefly/li ... 399-opp.dtsi#L81-85
  1.                 opp@1512000000 {
  2.                         opp-hz = /bits/ 64 <1512000000>;
  3.                         opp-microvolt = <1125000>;
  5.                         };
Copy the code
Are these frequencies omitted because they are unstable or due to an oversight?
super moderator
Rank: 8Rank: 8
Posted at 6/27/2017 10:35:54        Only Author  2#
if you  update  the kernel/resource  image by making it  yourself  ,then the missing part will show up.
Posted at 6/27/2017 22:43:04        Only Author  3#
Using the latest kernel does provide the missing frequencies.  I also confirmed a performance increase when using the frequencies.
Posted at 1/9/2026 17:06:29        Only Author  4#
Thank you for sharing such an insightful and uplifting article! Free MB-800 latest exam name questions—unlock your career advancement and salary boost!
Posted at 1/10/2026 17:04:42        Only Author  5#
Truly enjoyed this—immediate like! Here's the NSE5_FNC_AD_7.6 Related Exams test that helped me land my promotion and raise. It's free today—good luck with your career progress!
