u-boot environmental variable location ? and its offset and size ? in rk3128 (r
19
Posted at 6/29/2017 17:16:00      View4871 | Replies3        Print      Only Author   [Copy Link] 1#
Hi All,
       rk3128 (rockchip 3128)
       I  found in one of the header file about the u-boot environmental variables offset location as 0x0 and its size as 0x200.
       I tried to read the location in u-boot mode using "md " command . But I am not able to see the environmental variables in that
      location.Below is the command I am trying ,
       rkboot# md 0x00000000
       Can someone tel me where can I get the u-boot environmental variable location ? and its size.?
Thanks and Regards
   Shravan S
restricted members
Posted at 1/9/2026 16:53:49        Only Author  2#
This is truly a first-rate article, thank you for sharing. The Reliable test 300-510 dumps pdf content is impressive, and its free for you to explore.
restricted members
Posted at 1/18/2026 04:07:32        Only Author  3#
Im stunned by your article, thank you for this incredible share! The Reliable ZDTE test dumps questions are freeuse them to unlock promotions and higher earnings!
Posted at 1/20/2026 07:09:11        Only Author  4#
Your article was truly remarkable, Im sincerely grateful. Get the FCSS_SDW_AR-7.6 reliable exam simulator online questions for freeyour career and salary progression start here!
