4K UHD resolution (3840x2160) not supported
83
Posted at 7/3/2017 00:32:41      View4434 | Replies5        Print      Only Author   [Copy Link] 1#
Connecting the HDMI port to a 4K display only supports up to 1080p resolution.  The display, cable, and port used are all verified to support 4K with an Amlogic S905 based board from a different vendor.
Using the display settings GUI, only 1080p and lower resolutions are available.  Has anyone got 4K to work with the Ubuntu image? If so, what is the procedure?
[edit]
I should note that I am using the recent kernel compiled from source as instructed in the wiki.
super moderator
Rank: 8Rank: 8
Posted at 7/3/2017 09:57:47        Only Author  2#
Oh, please don't use 4K display in ubuntu, That is very slow, The 2D graphic driver is not good enough for 4K display!
Posted at 7/4/2017 04:28:58        Only Author  3#
Whether the device is slow or not is of no concern to me.  What is required for me to enable 4K UHD output?  Additionally, as I noted in another thread, when a 4K device is connected to the USB-C port, the device will not boot.  It locks up and displays garbage on the HDMI port.
Posted at 1/11/2026 02:38:19        Only Author  4#
This article is exceptional, I truly appreciate you sharing it! I hope the Valid AI-900 APP simulations content helps you, and best of all, its free!
Posted at 1/26/2026 19:54:35        Only Author  5#
After reading this article, my work thoughts have become clearer. Wish me all the success I can get for the ITIL-4-Transition test questions vce exam!
Posted at 2/2/2026 03:54:52        Only Author  6#
Absolutely brilliant content, no hesitation to like it. The CS0-003 Cert Exam materials are here for free. Wishing you good luck!
