OpenGL support and setup
78
Posted at 7/22/2017 03:49:53      View7492 | Replies5        Print      Only Author   [Copy Link] 1#
Hello, has anyone had luck running OpenGL on their firefly? If so what libraries or drivers did you use?
super moderator
Rank: 8Rank: 8
Posted at 7/22/2017 09:44:13        Only Author  2#
the OpenGL-ES is supported
please try:
sudo apt-get install glmark2-es2
glmark2-es2
Posted at 7/26/2017 06:19:49        Only Author  3#
THank you.  We have the Firefly RK3399 Plus 32GB model. Will this also require a Kernel update to work? Or is the latest Kernel already included with your Ubuntu distro?
Posted at 1/23/2026 19:32:41        Only Author  4#
MicrosoftAI-900JJ^ԇYϬFITIǤäȤ˚ݤäơԇY˺ϸ񤹤о¤ˤǤ CertJukenMicrosoftAI-900JMicrosoft Azure AI Fundamentals (AI-900ձZ)J^ԇYκϸʤߤΥ֥ȤǡCertJukenФITIΌTҤоͨMicrosoftAI-900JJ^ԇYˤĤƆ}оAƤޤ100%ϸʤϱˤоɹǤޤCertJukenxСɹޤ礦
Posted at 2/5/2026 04:46:06        Only Author  5#
This article is full of inspiration, thank you for posting it! Best of luck! Heres the free Valid VMCE_v12 test forum material shared with you.
Posted at 2/14/2026 05:48:09        Only Author  6#
This article is truly eye-opening, thank you for sharing. Strengthen your IT abilities with free New study guide JN0-224 ppt. Wishing you all the best!
