How can we root RK3399 device?
41
Posted at 8/18/2017 14:41:22      View:7274 | Replies:8        Print      Only Author   [Copy Link] 1#
Posted at 8/18/2017 18:35:38        Only Author  2#
I think it's already pretty much at root when you flash the firmware. The only thing that I've had trouble with is removing the RKBMC app and a few others, but there are root apps that can manage that for me.
Posted at 8/18/2017 20:05:13        Only Author  3#
ampstar Posted at 8/18/2017 18:35
I think it's already pretty much at root when you flash the firmware. The only thing that I've had t ...
we can access the su from Terminal but apps are not able to access the su. we are getting error operation not permitted.
Posted at 8/19/2017 09:21:45        Only Author  4#
Firefly-rk3399 root have already set in the developer options, just go to turn it on.
Posted at 8/20/2017 01:30:39        Only Author  5#
can you use that in Android?
Posted at 8/21/2017 12:28:40        Only Author  6#
leung先森 Posted at 8/19/2017 09:21
didnt find the root option in developer option. Can you please share the screenshot of your developer option?
Posted at 8/21/2017 13:07:30        Only Author  7#
Posted at 8/22/2017 07:48:47        Only Author  8#
I have the same problem and I have tried unsuccessfully to root the device.
If you search the forums people recommend downloading the "adb.exe" tool (Android Bridge Driver).
But when I plug the board into my PC, adb doesn't recognise it as a device.
I have tried playing around with the usb settings (MTP, PTP, etc.) ... but no luck.
Please let me know if you have luck rooting it because I need this solution as well.
Posted at 8/22/2017 09:11:35        Only Author  9#
Done. Factory Reset my RK3399 board and it worked.
So, follow the instructions here (http://bbs.t-firefly.com/forum.p ... &highlight=root) ... and you should be fine.
