Problem with wifi on ubuntu
Posted at 8/27/2017 08:32:42
Hi,
I managed to configure a custom xubuntu filesystem thanks to the tutorial with a lot of packages installed through qemu... Once the .img is done it boots and everything seems to work except the wifi.
The network manager keeps telling the "device is not ready". Restarting it doesn't change anything.
With :
I got : "SIOCSIFFLAGS: Operation not permitted". It seems the wifi adapter is powered off because there is no rfkill lock and :
returns :
[ 2048.920017] dhd_wl_ioctl: returning as busstate=0
[ 2048.920031] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 2048.923774] sdioh_disable_func_intr: error for read SDIO_CCCR_IENx : 0xffffff92
[ 2048.923798] wifi_platform_set_power = 0
[ 2048.923811] ======== PULL WL_REG_ON LOW! ========
[ 2048.923826] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 2048.923847] [WLAN_RFKILL]: wifi shut off power.
[ 2048.923860] wl_android_wifi_off out
[ 2048.949115] dhd_stop: Exit
[ 2048.949136] dhd_open: Exit ret=-1
and with
I got :
Aug 27 00:20:04 firefly kernel: ======== PULL WL_REG_ON LOW! ========
Aug 27 00:20:04 firefly kernel: [WLAN_RFKILL]: rockchip_wifi_power: 0
Aug 27 00:20:04 firefly kernel: [WLAN_RFKILL]: wifi shut off power.
Aug 27 00:20:04 firefly kernel: wl_android_wifi_on: Failed
Aug 27 00:20:04 firefly kernel: dhd_open : wl_android_wifi_on failed (-35)
Aug 27 00:20:04 firefly kernel: dhd_stop: Enter ffffffc0edcb4000
Aug 27 00:20:04 firefly kernel: wl_android_wifi_off in 1
Aug 27 00:20:04 firefly kernel: wl_android_wifi_off in 2: g_wifi_on=0, on_failur
Aug 27 00:20:04 firefly kernel: dhd_wl_ioctl: returning as busstate=0
Aug 27 00:20:04 firefly kernel: dhd_net_bus_devreset: dhd_bus_devreset: -35
Aug 27 00:20:04 firefly kernel: sdioh_disable_func_intr: error for read SDIO_CCC
Aug 27 00:20:04 firefly kernel: wifi_platform_set_power = 0
Aug 27 00:20:04 firefly kernel: wl_android_wifi_off out
Aug 27 00:20:04 firefly kernel: dhd_stop: Exit
Aug 27 00:20:04 firefly kernel: dhd_open: Exit ret=-1
Last, with serial debugging:
[ 2.359684] dhd_conf_set_txglom_params: swtxglom=0, txglom_ext=0
[ 2.360214] dhd_conf_set_txglom_params: txglom_bucket_size=0
[ 2.360710] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0, bus_txglom=0
[ 2.361398] dhd_conf_set_txglom_params: tx_in_rx=1, tx_max_offset=0
[ 2.361945] dhd_bus_devreset: WLAN OFF DONE
[ 2.362395] wifi_platform_set_power = 0
[ 2.362735] ======== PULL WL_REG_ON LOW! ========
[ 2.363156] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 2.363576] [WLAN_RFKILL]: wifi shut off power.
[ 2.364059] dhd_module_init: Exit err=0
The kernel is 4.4.55 (and everything worked with the vanilla filesystem)
Any idea ?
