Ubuntu Linux failed to boot!
15
Posted at 9/1/2017 02:52:01      View:9264 | Replies:7        Print      Only Author   [Copy Link] 1#
Hello everyone,
I tried to install Ubuntu onto RK3399 board.
Exact image file is " Firefly-rk3399_xubuntu1604_201705111112.img " .
When I flashed the image , system can't boot - it stops during kernel load - see UART debug below.
What is wrong ? Has anyone seen this as well?
DDR Version 1.07 20161103
In
Channel 0: LPDDR3, 666MHz
CS = 0
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x2
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
CS = 1
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x2
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=32 Size=2048MB
Channel 1: LPDDR3, 666MHz
CS = 0
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x2
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
CS = 1
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x2
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x2020
ch 1 ddrconfig = 0x101, ddrsize = 0x2020
pmugrf_os_reg[2] = 0x3AA0DAA0, stride = 0xD
OUT
Boot1: 2016-07-29, version: 1.05
CPUId = 0x0
ChipType = 10 1848
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=29820MB
FwPartOffset=2000 , 100000
SdmmcInit=0 20
StorageInit ok = 63984
LoadTrustBL
No find bl30.bin
No find bl32.bin
theLoader 200000 79548
LoaderFlag2: 0x0
WARNING: plat_rockchip_comm_sram_init:code:ff8d9000, 67000, ef0
NOTICE:  BL31: v1.2(debug):b995f80
NOTICE:  BL31: Built : 16:53:56, Nov  7 2016
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    boot cpu mask: 0
INFO:    Vesion: 2016.0.01
INFO:    plat_rockchip_pmu_init(1211): pd status 3e
INFO:    BL31: Initializing runtime services
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.02-RK3399-06-ga7c7ca8 (Apr 25 2017 - 15:10:21)
CPU: rk3399
cpu version = 0
CPU's clock information:
    aplll = 816000000HZ
    apllb = 24000000HZ
    gpll = 594000000HZ
               aclk_periph_h = 148500000HZ, hclk_periph_h = 74250000HZ, pclk_periph_h = 37125000HZ
               aclk_periph_l0 = 99000000HZ, hclk_periph_l0 = 99000000HZ, pclk_periph_l0 = 49500000HZ
               hclk_periph_l1 = 99000000HZ, pclk_periph_l1 = 49500000HZ
    cpll = 800000000HZ
    dpll = 660000000HZ
    vpll = 24000000HZ
    npll = 24000000HZ
    ppll = 676000000HZ
Board:  Rockchip platform Board
Uboot as second level loader
DRAM:  Found dram banks: 1
Adding bank:0000000000200000(00000000ffe00000)
128 MiB
SdmmcInit = 0 20
storage init OK!
Using default environment
GetParam
Load FDT from resource image.
no key node
usb bc: can find node by path: /dwc-control-usb/usb_bc
dwc_otg_check_dpdm: usb bc disconnected
pmic:rk808
can't find dts node for pwm1
set pwm voltage ok,pwm_id =2 vol=1000000,pwm_value=66
    aplll = 816000000HZ
    apllb = 24000000HZ
    gpll = 594000000HZ
    cpll = 800000000HZ
    dpll = 660000000HZ
    vpll = 24000000HZ
    npll = 24000000HZ
    ppll = 676000000HZ
Can't find dts node for fuel guage cw201x
can't find dts node for ec-battery
Can't find dts node for charger bq25700
SecureBootEn = 0, SecureBootLock = 0
#Boot ver: 2017-04-25#1.05
empty serial no.
normal boot.
checkKey
vbus = 0
no fuel gauge found
no fuel gauge found
read logo on state from dts [1]
no fuel gauge found
misc partition not found!
Hit any key to stop autoboot:  0
load fdt from resouce.
Secure Boot state: 0
kernel   @ 0x00280000 (0x01192e40)
ramdisk  @ 0x05bf0000 (0x00000000)
bootrk: do_bootm_linux...
   Loading Device Tree to 0000000005600000, end 0000000005613a89 ... OK
Add bank:0000000000200000, 00000000f7e00000
WARNING: could not set reg FDT_ERR_BADOFFSET.
Starting kernel ...
<hit enter to activate fiq debugger>
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.52 (whh@esky14) (gcc version 4.9.x-google 20140827 (prerelease) (GCC) ) #19 SMP Tue May 2 11:36:30 HKT 2017
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f7eea000 s46144 r8192 d31680 u86016
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 999432
[    0.000000] Kernel command line: console=ttyFIQ0 root=/dev/mmcblk1p6 rw rootwait mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00008000@0x00006000(resource),0x0000A000@0x0000E000(kernel),0x00002000@0x00018000(backup),-@0x0001A000(boot) storagemedia=emmc uboot_logo=0x02000000@0xf5c00000 loader.timestamp=2017-04-25_15:10:21
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] software IO TLB [mem 0xef600000-0xf3600000] (64MB) mapped at [ffffffc0ef600000-ffffffc0f35fffff]
[    0.000000] Memory: 3903556K/4061184K available (11454K kernel code, 1355K rwdata, 4016K rodata, 1152K init, 764K bss, 157628K reserved, 0K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000   (   246 GB)
[    0.000000]       .init : 0xffffff8008fa0000 - 0xffffff80090c0000   (  1152 KB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008bb0000   ( 11456 KB)
[    0.000000]     .rodata : 0xffffff8008bb0000 - 0xffffff8008fa0000   (  4032 KB)
[    0.000000]       .data : 0xffffff80090c0000 - 0xffffff8009212e40   (  1356 KB)
[    0.000000]     vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000   (     8 GB maximum)
[    0.000000]               0xffffffbdc0008000 - 0xffffffbdc3e00000   (    61 MB actual)
[    0.000000]     fixed   : 0xffffffbffe7fd000 - 0xffffffbffec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000   (    16 MB)
[    0.000000]     memory  : 0xffffffc000200000 - 0xffffffc0f8000000   (  3966 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000
[    0.000000] ITS: allocated 65536 Devices @ef000000 (psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GIC: using LPI property table @0x00000000ef080000
[    0.000000] ITS: Allocated 1792 chunks for LPIs
[    0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000
[    0.000000] CPU0: using LPI pending table @0x00000000ef090000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[    0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001180] Console: colour dummy device 80x25
[    0.001206] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[    0.001220] pid_max: default: 32768 minimum: 301
[    0.001312] Security Framework initialized
[    0.001322] Yama: becoming mindful.
[    0.001402] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.001413] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.002235] Initializing cgroup subsys devices
[    0.002258] Initializing cgroup subsys freezer
[    0.002286] ftrace: allocating 42895 entries in 168 pages
[    0.118883] sched-energy: Sched-energy-costs installed from DT
[    0.118902] CPU0: update cpu_capacity 401
[    0.118965] ASID allocator initialised with 65536 entries
[    0.119807] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.120232] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.121380] Detected VIPT I-cache on CPU1
[    0.121414] CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.121451] CPU1: using LPI pending table @0x00000000ef2a0000
[    0.121498] CPU1: update cpu_capacity 401
[    0.121503] CPU1: Booted secondary processor [410fd034]
[    0.122043] Detected VIPT I-cache on CPU2
[    0.122064] CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.122097] CPU2: using LPI pending table @0x00000000ef2d0000
[    0.122126] CPU2: update cpu_capacity 401
[    0.122129] CPU2: Booted secondary processor [410fd034]
[    0.122612] Detected VIPT I-cache on CPU3
[    0.122633] CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.122667] CPU3: using LPI pending table @0x00000000ef300000
[    0.122695] CPU3: update cpu_capacity 401
[    0.122698] CPU3: Booted secondary processor [410fd034]
[    0.123218] Detected PIPT I-cache on CPU4
[    0.123249] CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.123285] CPU4: using LPI pending table @0x00000000ef350000
[    0.123328] CPU4: update cpu_capacity 1024
[    0.123331] CPU4: Booted secondary processor [410fd082]
[    0.123853] Detected PIPT I-cache on CPU5
[    0.123872] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.123906] CPU5: using LPI pending table @0x00000000ef380000
[    0.123934] CPU5: update cpu_capacity 1024
[    0.123938] CPU5: Booted secondary processor [410fd082]
[    0.124025] Brought up 6 CPUs
[    0.124107] SMP: Total of 6 processors activated.
[    0.124116] CPU features: detected feature: GIC system register CPU interface
[    0.124129] CPU: All CPU(s) started at EL2
[    0.124176] alternatives: patching kernel code
[    0.125553] devtmpfs: initialized
[    0.145530] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[    0.145566] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.146113] pinctrl core: initialized pinctrl subsystem
[    0.147200] NET: Registered protocol family 16
[    0.151182] cpuidle: using governor ladder
[    0.155204] cpuidle: using governor menu
[    0.155231] Registered FIQ tty driver
[    0.155632] vdso: 2 pages (1 code @ ffffff8008bb6000, 1 data @ ffffff80090c4000)
[    0.155666] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.155861] DMA: preallocated 256 KiB pool for atomic allocations
[    0.245808] console [ttyFIQ0] enabled
[    0.246340] Registered fiq debugger ttyFIQ0
[    0.269899] ACPI: Interpreter disabled.
super moderator
Rank: 8Rank: 8
Posted at 9/1/2017 09:58:49        Only Author  2#
works well in android?
Posted at 9/3/2017 02:36:55        Only Author  3#
Tried Android (7.1) and got the same problem. Board hangs during boot. When push RSET it starts reboots in series , one after another. But with Android I can see a logo on HDMI monitor
Look like the board is faulty , I 'll look for another one .
Long UART output with Android is below - just in case ...
DDR Version 1.08 20170320
In
Channel 0: LPDDR3, 800MHz
CS = 0
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x2
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
CS = 1
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x2
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
Channel 1: LPDDR3, 800MHz
CS = 0
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x2
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
CS = 1
MR0=0x58
MR1=0x58
MR2=0x58
MR3=0x58
MR4=0x2
MR5=0x1
MR6=0x5
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
256B stride
OUT
Boot1: 2017-03-07, version: 1.06
CPUId = 0x0
ChipType = 0x10, 1836
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=29820MB
SdmmcInit=0 20
StorageInit ok = 68012
LoadTrustBL
No find bl30.bin
No find bl32.bin
RunBL31 0x10000
NOTICE:  BL31: v1.3(debug):55aa0b4
NOTICE:  BL31: Built : 16:55:03, Mar 31 2017
INFO:    plat_rockchip_pmu_init(1089): pd status 3e
INFO:    SPSR = 0x3c9
U-Boot 2017.02-RK3399-06 (May 16 2017 - 19:22:40)
CPU: rk3399
cpu version = 0
    aplll = 816000000HZ
    apllb = 24000000HZ
    gpll = 800000000HZ
               aclk_periph_h = 133333333HZ, hclk_periph_h = 66666666HZ, pclk_periph_h = 33333333HZ
               aclk_periph_l0 = 100000000HZ, hclk_periph_l0 = 100000000HZ, pclk_periph_l0 = 50000000HZ
               hclk_periph_l1 = 100000000HZ, pclk_periph_l1 = 50000000HZ
    cpll = 800000000HZ
    dpll = 792000000HZ
    vpll = 24000000HZ
    npll = 24000000HZ
    ppll = 676000000HZ
128 MiB
SdmmcInit = 0 20
storage init OK!
GetParam
remotectl v0.1
pwm freq=0xb8320
pwm_freq_nstime=0x52d
power key: bank-0 pin-5
pmic:rk808
    aplll = 816000000HZ
    apllb = 24000000HZ
    gpll = 800000000HZ
    cpll = 800000000HZ
    dpll = 792000000HZ
    vpll = 24000000HZ
    npll = 24000000HZ
    ppll = 676000000HZ
#Boot ver: 2017-05-16#1.06
empty serial no.
normal boot.
checkKey
vbus = 0
board_fbt_key_pressed: ir_keycode = 0x0, frt = 0
no fuel gauge found
no fuel gauge found
failed to find phy node
can't find power_ctr node for panel
enable[0] disable[0]
no fuel gauge found
can't find dts node for deviceinfo
dw_rk_hdmi_register:fail to read deviceinfo
hdmi baseparamer 1478502959x706760016@1634231072-1953696303
ERROR: [get_entry_ram]: Cannot find logo_kernel.bmp!
failed to display kernel logo
checkKey
vbus = 0
got recovery cmd from misc.
kernel   @ 0x00280000 (0x011f7420)
ramdisk  @ 0x05bf0000 (0x00778ae8)
   Loading Device Tree to 0000000005600000, end 0000000005614937 ... OK
Starting kernel ...
[    0.000000] Initializing cgroup subsys schedtune
[    0.000000] Linux version 4.4.55 (firefly@tchip-server) (gcc version 4.9 20150123 (prerelease) (GCC) ) #2 SMP PREEMPT Mon May 15 11:04:11 CST 2017
[    0.000000] earlycon: Early serial console at MMIO32 0xff1a0000 (options '')
[    0.000000] bootconsole [uart0] enabled
[    0.000000] hdmi init vic is -1
[    0.000000] cma: Reserved 16 MiB at 0x00000000f7000000
[    0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f6ef6000 s45248 r8192 d32576 u86016
[    0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 androidboot.baseband=N/A androidboot.selinux=permissive androidboot.hardware=rk30board androidboot.console=ttyFIQ0 init=/init mtdparts=rk29xxnand:0x00002000@0x00000000(parameter),0x00002000@0x00002000(uboot),0x00002000@0x00004000(trust),0x00002000@0x00006000(misc),0x00008000@0x00008000(resource),0x0000C000@0x00010000(kernel),0x00010000@0x0001C000(boot),0x00010000@0x0002C000(recovery),0x00038000@0x0003C000(backup),0x00040000@0x00074000(cache),0x00300000@0x000B4000(system),0x00008000@0x003B4000(metadata),0x00002000@0x003BC000(baseparamer),-@0x003BE000(userdata) storagemedia=emmc uboot_logo=0x02000000@0xf5c00000 loader.timestamp=2017-05-16_19:22:41 hdmi.vic=-1 SecureBootCheckOk=0
[    0.000000] software IO TLB [mem 0xf6eae000-0xf6eee000] (0MB) mapped at [ffffffc0f6eae000-ffffffc0f6eedfff]
[    0.000000] Memory: 3944008K/4061184K available (11198K kernel code, 1372K rwdata, 4948K rodata, 832K init, 1079K bss, 100792K reserved, 16384K cma-reserved)
[    0.000000]       .init : 0xffffff8009050000 - 0xffffff8009120000   (   832 KB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008b70000   ( 11200 KB)
[    0.000000]     .rodata : 0xffffff8008b70000 - 0xffffff8009050000   (  4992 KB)
[    0.000000]       .data : 0xffffff8009120000 - 0xffffff80092772e0   (  1373 KB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] ITS: allocated 65536 Devices @f2000000 (psz 64K, shr 0)
[    0.000000] GIC: using LPI property table @0x00000000f2080000
[    0.000000] CPU0: using LPI pending table @0x00000000f2090000
[    0.000000] rockchip_cpuclk_pre_rate_change: limiting alt-divider 33 to 31
[    0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.001803] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[    0.002767] pid_max: default: 32768 minimum: 301
[    0.003263] Security Framework initialized
[    0.003652] SELinux:  Initializing.
[    0.004085] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.004715] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.006208] Initializing cgroup subsys freezer
[    0.006637] Initializing cgroup subsys debug
[    0.007904] sched-energy: Sched-energy-costs installed from DT
[    0.008452] CPU0: update cpu_capacity 401
[    0.008911] ASID allocator initialised with 65536 entries
[    0.025729] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.026963] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.039115] Detected VIPT I-cache on CPU1
[    0.039146] CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.039182] CPU1: using LPI pending table @0x00000000f2200000
[    0.039225] CPU1: update cpu_capacity 401
[    0.039228] CPU1: Booted secondary processor [410fd034]
[    0.049114] Detected VIPT I-cache on CPU2
[    0.049132] CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.049165] CPU2: using LPI pending table @0x00000000f2230000
[    0.049193] CPU2: update cpu_capacity 401
[    0.049196] CPU2: Booted secondary processor [410fd034]
[    0.059152] Detected VIPT I-cache on CPU3
[    0.059171] CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.059203] CPU3: using LPI pending table @0x00000000f2270000
[    0.059230] CPU3: update cpu_capacity 401
[    0.059233] CPU3: Booted secondary processor [410fd034]
[    0.069190] Detected PIPT I-cache on CPU4
[    0.069217] CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.069252] CPU4: using LPI pending table @0x00000000f22b0000
[    0.069293] CPU4: update cpu_capacity 1024
[    0.069296] CPU4: Booted secondary processor [410fd082]
[    0.079219] Detected PIPT I-cache on CPU5
[    0.079237] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.079270] CPU5: using LPI pending table @0x00000000f22f0000
[    0.079297] CPU5: update cpu_capacity 1024
[    0.079300] CPU5: Booted secondary processor [410fd082]
[    0.079384] Brought up 6 CPUs
[    0.091481] SMP: Total of 6 processors activated.
[    0.091923] CPU features: detected feature: GIC system register CPU interface
[    0.092593] CPU: All CPU(s) started at EL2
[    0.093016] alternatives: patching kernel code
[    0.094671] devtmpfs: initialized
[    0.114251] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.115185] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.116804] pinctrl core: initialized pinctrl subsystem
[    0.119830] Failed to find legacy iommu devices
[    0.120814] NET: Registered protocol family 16
[    0.121948] schedtune: init normalization constants...
[    0.122435] schedtune: CLUSTER[0-3]      min_pwr:    56 max_pwr:   222
[    0.123046] schedtune: CPU[0]            min_pwr:     0 max_pwr:   222
[    0.123656] schedtune: CPU[1]            min_pwr:     0 max_pwr:   222
[    0.124281] schedtune: CPU[2]            min_pwr:     0 max_pwr:   222
[    0.124893] schedtune: CPU[3]            min_pwr:     0 max_pwr:   222
[    0.125505] schedtune: CLUSTER[4-5]      min_pwr:    65 max_pwr:  1108
[    0.126116] schedtune: CPU[4]            min_pwr:     0 max_pwr:  1108
[    0.126727] schedtune: CPU[5]            min_pwr:     0 max_pwr:  1108
[    0.127338] schedtune: SYSTEM            min_pwr:   121 max_pwr:  4434
[    0.127959] schedtune: using normalization constants mul: 3862781856 sh1: 1 sh2: 12
[    0.128672] schedtune: verify normalization constants...
[    0.129170] schedtune: max_pwr/2^0: 4313 => norm_pwr:  1024
[    0.129691] schedtune: max_pwr/2^1: 2156 => norm_pwr:   511
[    0.130212] schedtune: max_pwr/2^2: 1078 => norm_pwr:   255
[    0.130734] schedtune: max_pwr/2^3:  539 => norm_pwr:   127
[    0.131256] schedtune: max_pwr/2^4:  269 => norm_pwr:    63
[    0.131786] schedtune: max_pwr/2^5:  134 => norm_pwr:    31
[    0.132307] schedtune: configured to support 4 boost groups
[    0.141827] cpuidle: using governor ladder
[    0.155186] cpuidle: using governor menu
[    0.155572] Registered FIQ tty driver
[    0.156558] vdso: 2 pages (1 code @ ffffff8008b76000, 1 data @ ffffff8009124000)
[    0.157275] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.158729] DMA: preallocated 256 KiB pool for atomic allocations
[    0.183307] console [pstore0] enabled
[    0.183857] pstore: Registered ramoops as persistent store backend
[    0.184440] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[    0.188217] console [ttyFIQ0] enabled
[[    0.188217] console [ttyFIQ0] enabled
[    0.188778] bootconsole [uart0] disabled
[    0.189993] Registered fiq debugger ttyFIQ0
[    0.237178] Rockchip hdmi driver version 2.0
[    0.239249] iommu: Adding device ff650000.vpu_service to group 0
[    0.239332] iommu: Adding device ff660000.rkvdec to group 1
[    0.239397] iommu: Adding device ff670000.iep to group 2
[    0.239529] iommu: Adding device ff8f0000.vop to group 3
[    0.239604] iommu: Adding device ff900000.vop to group 4
[    0.239696] iommu: Adding device ff910000.isp to group 5
[    0.239770] iommu: Adding device ff920000.isp to group 6
[    0.240413] rk_iommu ff670800.iommu: can't get aclk
[    0.240435] rk_iommu ff670800.iommu: can't get hclk
[    0.241240] SCSI subsystem initialized
[    0.241589] usbcore: registered new interface driver usbfs
[    0.241634] usbcore: registered new interface driver hub
[    0.241710] usbcore: registered new device driver usb
[    0.242040] media: Linux media interface: v0.10
[    0.242080] Linux video capture interface: v2.00
[    0.242201] pps_core: LinuxPPS API ver. 1 registered
[    0.242212] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.242236] PTP clock support registered
[    0.243516] Advanced Linux Sound Architecture Driver Initialized.
[    0.243994] Bluetooth: Core ver 2.21
[    0.244024] NET: Registered protocol family 31
[    0.244035] Bluetooth: HCI device and connection manager initialized
[    0.244051] Bluetooth: HCI socket layer initialized
[    0.244064] Bluetooth: L2CAP socket layer initialized
[    0.244092] Bluetooth: SCO socket layer initialized
[    0.245351] clocksource: Switched to clocksource arch_sys_counter
[    0.283862] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[    0.284078] NET: Registered protocol family 2
[    0.284503] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    0.284689] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[    0.284930] TCP: Hash tables configured (established 32768 bind 32768)
[    0.285006] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[    0.285060] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[    0.285237] NET: Registered protocol family 1
[    0.285736] Trying to unpack rootfs image as initramfs...
[    0.609067] Freeing initrd memory: 7648K (ffffffc005bf0000 - ffffffc006368000)
[    0.609615] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.609701] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.612198] audit: initializing netlink subsys (disabled)
[    0.612261] audit: type=2000 audit(0.606:1): initialized
[    0.620548] VFS: Disk quotas dquot_6.6.0
[    0.620674] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.622044] fuse init (API version 7.23)
[    0.626594] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.626623] io scheduler noop registered
[    0.626783] io scheduler cfq registered (default)
[    0.628007] rockchip-usb2phy ff770000.syscon:usb2-phy@e460: vbus_drv is not assigned
[    0.632069] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[    0.632098] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[    0.632116] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[    1.635355] pll lock timeout!
[    1.635376] phy phy-phy@e220.5: phy poweron failed --> -22
[    1.635390] rockchip-pcie f8000000.pcie: fail to power on phy, err -22
[    1.635448] rockchip-pcie: probe of f8000000.pcie failed with error -22
[    1.636079] rockchip ion idev is NULL
[    1.636093] rga2 ff680000.rga: rga ion client create success!
[    1.636266] rga: Driver loaded successfully ver:3.02
[    1.636932] iep: failed to find iep power down clock source.
[    1.637273] IEP Power ON
[    1.637429] IEP Power OFF
[    1.637459] IEP Driver loaded succesfully
[    1.637545] Module initialized.
[    1.641272] rk-vcodec ff650000.vpu_service: No core reset resource define
[    1.641328] rk-vcodec ff650000.vpu_service: do not have pd_video
[    1.641351] rk-vcodec ff650000.vpu_service: probe device
[    1.641392] rk-vcodec ff650000.vpu_service: vpu mmu dec ffffffc0f231e810
[    1.641531] rk-vcodec ff650000.vpu_service: allocator is drm
[    1.641589] rk-vcodec ff650000.vpu_service: checking hw id 0
[    1.641993] rk-vcodec ff650000.vpu_service: init success
[    1.645673] rk-vcodec ff660000.rkvdec: No core reset resource define
[    1.645782] rk-vcodec ff660000.rkvdec: do not have pd_video
[    1.645802] rk-vcodec ff660000.rkvdec: probe device
[    1.645843] rk-vcodec ff660000.rkvdec: vpu mmu dec ffffffc0f231f010
[    1.645976] rk-vcodec ff660000.rkvdec: allocator is drm
[    1.646034] rk-vcodec ff660000.rkvdec: checking hw id 6876
[    1.646328] rk-vcodec ff660000.rkvdec: init success
[    1.647708] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    1.647729] dma-pl330 ff6d0000.dma-controller:       DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[    1.649075] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    1.649093] dma-pl330 ff6e0000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
k6▒▒Ks3{6▒▒Ks3{▒6▒▒Kz
                    cK  : eff542b019a556dd
[    1.650499] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.651785] console [ttyS0] disabled
[    1.651828] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 35, base_baud = 1500000) is a 16550A
[    1.652391] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 36, base_baud = 1500000) is a 16550A
[    1.652775] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[    1.656489] mali ff9a0000.gpu: Failed to get regulator
[    1.656513] mali ff9a0000.gpu: Power control initialization failed
[    1.656805] Unable to detect cache hierarchy from DT for CPU 0
[    1.667722] brd: module loaded
[    1.672345] loop: module loaded
[    1.672840] zram: Added device: zram0
[    1.673363] SCSI Media Changer driver v0.25
[    1.674305] tun: Universal TUN/TAP device driver, 1.6
[    1.674322] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.675396] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[    1.675424] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[    1.675439] rk_gmac-dwmac fe300000.ethernet: RX delay(0x1b).
[    1.675628] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[    1.675641] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[    1.680716] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    1.680733]  Ring mode enabled
[    1.680742]  DMA HW capability register supported
[    1.680751]  Normal descriptors
[    1.680763]  RX Checksum Offload Engine supported (type 2)
[    1.680772]  TX Checksum insertion supported
[    1.680781]  Wake-Up On Lan supported
[    1.680824]  Enable RX Mitigation via HW Watchdog Timer
[    1.746263] libphy: stmmac: probed
[    1.746283] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[    1.746295] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[    1.747011] PPP generic driver version 2.4.2
[    1.747180] PPP BSD Compression module registered
[    1.747194] PPP Deflate Compression module registered
[    1.747222] PPP MPPE Compression module registered
[    1.747240] NET: Registered protocol family 24
[    1.747280] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[    1.747292] CSLIP: code copyright 1989 Regents of the University of California.
[    1.747315] Rockchip WiFi SYS interface (V1.00) ...
[    1.747397] usbcore: registered new interface driver catc
[    1.747439] usbcore: registered new interface driver kaweth
[    1.747454] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    1.747491] usbcore: registered new interface driver pegasus
[    1.747532] usbcore: registered new interface driver rtl8150
[    1.747572] usbcore: registered new interface driver r8152
[    1.747587] hso: drivers/net/usb/hso.c: Option Wireless
[    1.747643] usbcore: registered new interface driver hso
[    1.747691] usbcore: registered new interface driver asix
[    1.747732] usbcore: registered new interface driver ax88179_178a
[    1.747772] usbcore: registered new interface driver cdc_ether
[    1.747816] usbcore: registered new interface driver cdc_eem
[    1.747862] usbcore: registered new interface driver dm9601
[    1.747913] usbcore: registered new interface driver smsc75xx
[    1.747962] usbcore: registered new interface driver smsc95xx
[    1.748002] usbcore: registered new interface driver gl620a
[    1.748045] usbcore: registered new interface driver net1080
[    1.748085] usbcore: registered new interface driver plusb
[    1.748126] usbcore: registered new interface driver rndis_host
[    1.748168] usbcore: registered new interface driver cdc_subset
[    1.748208] usbcore: registered new interface driver zaurus
[    1.748249] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    1.748309] usbcore: registered new interface driver int51x1
[    1.748349] usbcore: registered new interface driver kalmia
[    1.748390] usbcore: registered new interface driver ipheth
[    1.748435] usbcore: registered new interface driver sierra_net
[    1.748476] usbcore: registered new interface driver cx82310_eth
[    1.748528] usbcore: registered new interface driver cdc_ncm
[    1.748569] usbcore: registered new interface driver qmi_wwan
[    1.748612] usbcore: registered new interface driver cdc_mbim
[    1.749758] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[    1.752909] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[    1.753479] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.753498] ehci-pci: EHCI PCI platform driver
[    1.753553] ehci-platform: EHCI generic platform driver
[    1.755327] ehci-platform fe3c0000.usb: EHCI Host Controller
[    1.755374] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 1
[    1.755517] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[    1.765378] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[    1.765504] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.765520] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.765534] usb usb1: Product: EHCI Host Controller
[    1.765545] usb usb1: Manufacturer: Linux 4.4.55 ehci_hcd
[    1.765556] usb usb1: SerialNumber: fe3c0000.usb
[    1.766013] hub 1-0:1.0: USB hub found
[    1.766045] hub 1-0:1.0: 1 port detected
[    1.766513] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.766542] ohci-platform: OHCI generic platform driver
[    1.766991] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[    1.767018] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 2
[    1.767141] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[    1.822823] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    1.822843] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.822858] usb usb2: Product: Generic Platform OHCI controller
[    1.822870] usb usb2: Manufacturer: Linux 4.4.55 ohci_hcd
[    1.822882] usb usb2: SerialNumber: fe3e0000.usb
[    1.823291] hub 2-0:1.0: USB hub found
[    1.823323] hub 2-0:1.0: 1 port detected
[    1.824066] usbcore: registered new interface driver cdc_acm
[    1.824079] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    1.824138] usbcore: registered new interface driver usblp
[    1.824184] usbcore: registered new interface driver cdc_wdm
[    1.824230] usbcore: registered new interface driver uas
[    1.824306] usbcore: registered new interface driver usb-storage
[    1.824348] usbcore: registered new interface driver ums-alauda
[    1.824389] usbcore: registered new interface driver ums-cypress
[    1.824430] usbcore: registered new interface driver ums-datafab
[    1.824472] usbcore: registered new interface driver ums_eneub6250
[    1.824513] usbcore: registered new interface driver ums-freecom
[    1.824557] usbcore: registered new interface driver ums-isd200
[    1.824598] usbcore: registered new interface driver ums-jumpshot
[    1.824641] usbcore: registered new interface driver ums-karma
[    1.824683] usbcore: registered new interface driver ums-onetouch
[    1.824724] usbcore: registered new interface driver ums-sddr09
[    1.824765] usbcore: registered new interface driver ums-sddr55
[    1.824807] usbcore: registered new interface driver ums-usbat
[    1.824882] usbcore: registered new interface driver usbserial
[    1.824918] usbcore: registered new interface driver usbserial_generic
[    1.824952] usbserial: USB Serial support registered for generic
[    1.824994] usbcore: registered new interface driver option
[    1.825023] usbserial: USB Serial support registered for GSM modem (1-port)
[    1.825123] usbcore: registered new interface driver trancevibrator
[    1.825140] usb20_otg: version 3.10a 21-DEC-2012
[    1.825294] usb20_host: version 3.10a 21-DEC-2012
[    1.829098] usbcore: registered new interface driver xpad
[    1.829151] usbcore: registered new interface driver usb_acecad
[    1.829197] usbcore: registered new interface driver aiptek
[    1.829244] usbcore: registered new interface driver gtco
[    1.829292] usbcore: registered new interface driver hanwang
[    1.829337] usbcore: registered new interface driver kbtab
[    1.829353] ==gsl_ts_init==
[    1.829381] ret=0
[    1.833104] .. rk pwm remotectl v1.1 init
[    1.833329] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[    1.833728] sensor_register_slave:mma8452,id=17
[    1.833746] sensor_register_slave:lis3dh,id=7
[    1.833761] sensor_register_slave:mma7660,id=18
[    1.833776] sensor_register_slave:lsm303d,id=22
[    1.833791] sensor_register_slave:mpu6880_acc,id=24
[    1.833805] sensor_register_slave:mpu6500_acc,id=25
[    1.833820] sensor_register_slave:lsm330_acc,id=26
[    1.833836] sensor_register_slave:akm8975,id=28
[    1.833851] sensor_register_slave:akm8963,id=29
[    1.833865] sensor_register_slave:l3g4200d,id=43
[    1.833880] sensor_register_slave:l3g20d,id=44
[    1.833895] sensor_register_slave:ewtsa,id=45
[    1.833910] sensor_register_slave:lsm330_gyro,id=48
[    1.833925] sensor_register_slave:cm3217,id=50
[    1.833939] sensor_register_slave:cm3218,id=51
[    1.834553] i2c /dev entries driver
[    1.835690] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    1.835755] fan53555-reg: supplied by vcc5v0_sys
[    1.837967] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    1.838014] fan53555-reg: supplied by vcc5v0_sys
[    1.840076] rk808 0-001b: Pmic Chip id: 0x0
[    1.843159] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    1.843212] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    1.843303] DCDC_REG1: supplied by vcc3v3_sys
[    1.843941] DCDC_REG2: supplied by vcc3v3_sys
[    1.844432] DCDC_REG3: supplied by vcc3v3_sys
[    1.844630] DCDC_REG4: supplied by vcc3v3_sys
[    1.844991] LDO_REG1: supplied by vcc3v3_sys
[    1.846024] LDO_REG2: supplied by vcc3v3_sys
[    1.846902] LDO_REG3: supplied by vcc3v3_sys
[    1.847775] LDO_REG4: supplied by vcc3v3_sys
[    1.848669] LDO_REG5: supplied by vcc3v3_sys
[    1.849569] LDO_REG6: supplied by vcc3v3_sys
[    1.850444] LDO_REG7: supplied by vcc3v3_sys
[    1.851339] LDO_REG8: supplied by vcc3v3_sys
[    1.852229] SWITCH_REG1: supplied by vcc3v3_sys
[    1.852436] SWITCH_REG2: supplied by vcc3v3_sys
[    1.855716] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0
[    1.856224] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80095fe000
[    1.856765] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff8009682000
[    1.869939] fusb302 4-0022: port 0 probe success
[    1.869976] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff8009684000
[    1.870790] IR NEC protocol handler initialized
[    1.870804] IR RC5(x/sz) protocol handler initialized
[    1.870818] IR RC6 protocol handler initialized
[    1.870831] IR JVC protocol handler initialized
[    1.870844] IR Sony protocol handler initialized
[    1.870857] IR SANYO protocol handler initialized
[    1.870870] IR Sharp protocol handler initialized
[    1.870883] IR MCE Keyboard/mouse protocol handler initialized
[    1.870896] IR XMP protocol handler initialized
[    1.870985] usbcore: registered new interface driver uvcvideo
[    1.870995] USB Video Class driver (1.1.1)
[    1.871024] CamSys driver version: v0.33.11, CamSys head file version: v0.13.0
[    1.872075] D1:camsys_platform_probe(1399): compatible is rockchip,rk3399-isp
[    1.872075]
[    1.872159] D1:camsys_mipiphy_probe_cb(204): ff910000.isp mipi phy0 probe success (reg_phy: 0x0  reg_vir: 0x0  size: 0x0)
[    1.872159]
[    1.872183] D1:camsys_mipiphy_probe_cb(204): ff910000.isp mipi phy1 probe success (reg_phy: 0x0  reg_vir: 0x0  size: 0x0)
[    1.872183]
[    1.872998] D1:camsys_platform_probe(1527): ff910000.isp memory:
[    1.873013] D1:camsys_platform_probe(1543):  Register memory (phy: 0xff910000 vir: 0xffffff8009688000 size: 0x4000)
[    1.873029] D1:camsys_platform_probe(1535):  I2c memory (phy: 0x5cc3000 vir: 0xffffffc005cc3000 size: 0x1000)
[    1.873043] D1:camsys_init_ext_fsh_module(20): init external flash module
[    1.873054] D1:camsys_platform_probe(1557): Probe ff910000.isp device success
[    1.874190] D1:camsys_platform_probe(1399): compatible is rockchip,rk3399-isp
[    1.874190]
[    1.874256] D1:camsys_mipiphy_probe_cb(204): ff920000.isp mipi phy0 probe success (reg_phy: 0x0  reg_vir: 0x0  size: 0x0)
[    1.874256]
[    1.874281] D1:camsys_mipiphy_probe_cb(204): ff920000.isp mipi phy1 probe success (reg_phy: 0x0  reg_vir: 0x0  size: 0x0)
[    1.874281]
[    1.875018] D1:camsys_platform_probe(1527): ff920000.isp memory:
[    1.875032] D1:camsys_platform_probe(1543):  Register memory (phy: 0xff920000 vir: 0xffffff80096b8000 size: 0x4000)
[    1.875047] D1:camsys_platform_probe(1535):  I2c memory (phy: 0x5cdd000 vir: 0xffffffc005cdd000 size: 0x1000)
[    1.875061] D1:camsys_init_ext_fsh_module(20): init external flash module
[    1.875072] D1:camsys_platform_probe(1557): Probe ff920000.isp device success
[    1.875412] __power_supply_register: Expected proper parent device for 'test_ac'
[    1.875539] __power_supply_register: Expected proper parent device for 'test_battery'
[    1.875777] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[    1.875880] __power_supply_register: Expected proper parent device for 'test_usb'
[    1.877086] rockchip_cpu_avs: cluster0 leakage=18 adjust_volt=0
[    1.877125] rockchip_cpu_avs: cluster1 leakage=32 adjust_volt=0
[    1.878198] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[    1.878812] device-mapper: uevent: version 1.0.3
[    1.879097] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    1.882588] Bluetooth: HCI UART driver ver 2.3
[    1.882602] Bluetooth: HCI UART protocol H4 registered
[    1.882613] Bluetooth: HCI UART protocol LL registered
[    1.882627] rtk_btusb: RTKBT_RELEASE_NAME: 20170109_TV_ANDROID_6.x
[    1.882638] rtk_btusb: Realtek Bluetooth USB driver module init, version 4.1.2
[    1.882648] rtk_btusb: Register usb char device interface for BT driver
[    1.882844] usbcore: registered new interface driver rtk_btusb
[    1.
Posted at 9/4/2017 09:56:09        Only Author  4#
dmitry Posted at 9/3/2017 02:36
Tried Android (7.1) and got the same problem. Board hangs during boot. When push RSET it starts rebo ...
why do not try the newest android7.1 firmware
Posted at 9/4/2017 16:51:47        Only Author  5#
The board came with preinstalled Andriod 7.1.2 and it was running ok
But we need Ubuntu for our project. When I flashed a second board with Firefly-rk3399_xubuntu1604_201705111112.img , I got the similar issue , nothing on HDMI monitor .  What could be a reason for this?  The only difference with flashing guide is that I used Windows 10 on host machine (don't have anything else at the moment) ? Could it be a reason ?
super moderator
Rank: 8Rank: 8
Posted at 9/5/2017 14:35:56        Only Author  6#
Hi
the second board. with the same UART log?
Posted at 9/20/2017 18:13:59        Only Author  7#
Please use pastebin when pasting walls of text
https://pastebin.com/
Posted at 11/9/2017 01:24:55        Only Author  8#
Hi dmitry,
did you meanwhile fix this problem ? I have exactly the same issue. My hardware revision is VS-RK3399-V2.0, 20170729.
