Root in Android
2
Root in Android
Posted at 12/16/2014 10:50:07      View15207 | Replies9        Print      Only Author   [Copy Link] 1#
Im going to introduce a quick way to root in Android, which will help get access to some powerful apks. The following progress is based on Linux.
1.Connect the open-source board to a PC and make sure adb is functioning.
2.Run the quick_root.tar in the attached files. Run the command: tar xf quick_root.tar.
3.Run the following commands.
adb remount
adb push root.tar system/usr/root.tar
adb push quick_root.sh system/usr/
adb shell
And then run the following commands.
root@rk3288:/ # cd system/usr/
root@rk3288:/system/usr # chmod 777 quick_root.sh
root@rk3288:/system/usr # ./quick_root.sh
After that, the configuration files will be installed automatically and the device will be rebooted.The device will be rooted after reboot.
4. Open the RE explorer and test if the root is successful.
1) Open the RE explorer and go to system/app.
2) Click the Mount R/W button on the upper left.You will see a pop-up window for superuser permission.
3) Delete apks under system/app via RE explorer. If you can delete them, it means that the device has been rooted.
root.zip (1.16 MB, Down times: 281)
quick_root.tar (10 KB, Down times: 220)
Posted at 12/16/2014 12:18:44        Only Author  2#
Rooting with this method has an extra gift, which is the program "Root Explorer" one of my favorites for digging deep and editing the file systems.  Another program since you are now rooted is "SetCPU", if nothing more than to be able to monitor your CPU Temperature, a surprise to me that Firefly would engineer this in.  KUDO's ENGINEERS.
Posted at 1/3/2015 23:57:26        Only Author  3#
where I can find root.tar?
Posted at 1/11/2015 03:20:16        Only Author  4#
Found this, this a.m. at CrewRKTablets.  Works, used it to check compatibility with Firefly.  Really like a new use for the rktools, but that is a choice.  This program is completely  GUI friendly.  Root your Firefly and also add TWRP from rktools 2.3.  Use the TWRP version, the CWM from reading may not work for sounds like touch.  enjoy http://crewrktablets.arctablet.com/?p=4776 Thanks to Netlars
EDIT: Got my p's and q's mixed use TWRP "Sorry"
---cappybob
Posted at 1/12/2017 15:29:27        Only Author  5#
Does this root Android 5.1 without PC? I heard many rooting app failed to do this.
Posted at 3/1/2018 17:39:28        Only Author  6#
Unfortunately, doesn't work anymore.
SuperSu mentioned "there is no SU binary installed, and SuperSu can't install it".
Posted at 1/11/2026 01:12:53        Only Author  7#
Im deeply impressed by your article, thank you for sharing it! The CY0-001 latest test report exam is coming soon. Fingers crossed for success!
Posted at 1/14/2026 02:20:12        Only Author  8#
So much wisdom in this article, thank you for sharing it! Wishing myself all the best for the C-THR85-2505 test engine version exam!
