New Topic
RK3399 Fails to Enable PCIe M.2 (B-Key) SSD Adapter Board
62
Posted at 9/18/2017 01:06:31      View6617 | Replies10        Print      Only Author   [Copy Link] 1#
Hello,
I bought the B-Key SSD Adapter board from the Firefly store and mounted it into my RK3399 board. I have a 120 GB SSD from SanDIsk connected via the supplied cables. Alas, I did not find my drive under /dev after booting Xubuntu 16.04 (I am using official T-Firefly release Firefly-rk3399_xubuntu1604_201705111112). When I checked dmesg, I noticed a lot of errors related to PCIe. If there is anyone on the forum who had a similar problem and solved it, please share the solution. For any interested developers, I am attaching the dmesg capture to this thread.
Any help will be greatly appreciated!
ffly_rk3399_4.4.52.log.zip
21.52 KB, Down times: 9
boot log
Posted at 10/1/2017 03:23:20        Only Author  2#
Nvm
Posted at 10/18/2017 16:36:57        Only Author  3#
huh?
Posted at 6/5/2018 03:53:08        Only Author  4#
So - not sure if you got anywhere with this but the errors in the log say that the pcie bus isn't configured to be powered up in the device tree - have you grabbed a newer ubuntu image & tried again?
As far as I know the device tree is configured in the dts files at compile time
I'll be honest I'm investigating a similar problem with m.2 - different card though - I would be interested to hear if you have had any luck
Posted at 6/10/2018 05:51:57        Only Author  5#
OK, a closer look at your logs show that the PCIE bus is actually coming up, and attempting to enable a device
you should be able to see the sata adapter with lspci - if you can't then try a newer image - there is a quite recent one
Posted at 1/9/2026 09:38:17        Only Author  6#
Thank you for your article; it truly shocked me! Best of luck! Here are the free XSIAM-Analyst valid exam objectives materials to help you!
restricted members
Posted at 1/12/2026 22:54:12        Only Author  7#
I was really impressed by the depth and breadth of the article. SOL-C01 latest practice test online provides quality content, and its completely free.
Posted at 1/14/2026 12:26:40        Only Author  8#
Thank you for sharing such a motivational and uplifting article! The L5M8 reliable exam dumps demo study materials are available for freegood luck!
Posted at 1/18/2026 02:12:34        Only Author  9#
This article is incredibly motivating, thank you for sharing it! This is the 220-1202 vce exam exam I took to get my promotion and pay raise, now available to you for free today. I hope you reach your professional goals soon!
Posted at 2/5/2026 04:10:20        Only Author  10#
This article is so uplifting, thank you for sharing it! Sharing the EX-Con-101 reliable real test answer exam that got me my promotion and salary raiseits free for all today. Hope you all achieve your professional dreams!
Return to List
12
