Performance Monitor Counters (Firefly-RK3399)
11
Posted at 9/18/2017 02:45:22      View:4242 | Replies:3        Print      Only Author   [Copy Link] 1#
Hello
I am using Ubuntu 16.04  with kernel 4.4.55 which I believe it is the latest (build from the master branch).
I noticed that performance monitor counters for both A53 and A72 do not work. When I am
trying to access from the user space, I get "illegal instruction".
Normally this happens if user level access is not enabled. But  I have enabled PMU user level access
by loading a kernel module.
In the Linux boot logs I am seeing the following message which indicates hardware supports
CPU performance monitor counters.
firefly@firefly:~$ dmesg | grep PMU
[    0.336204] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    0.337025] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
Has anybody tested this feature on this board?
Am I missing a steps?.
This process works on other platforms. Any hint that why this is broken on Firefly-RK3399?
Regards, Reza
Posted at 1/28/2026 07:55:58        Only Author  2#
Your article really made an impact, I’m very appreciative. I achieved career success with the ServSafe-Manager reliable exam cram materials, earning both a promotion and raise. It’s free for everyone now. Best of luck!
Posted at 2/6/2026 01:58:01        Only Author  3#
This article really resonated with me, thank you for sharing! The rich material in Reliable CLF-C02 practice questions sheet is available to you for free, intended to help you.
Posted at 2/23/2026 02:00:54        Only Author  4#
你想在IT行業中大顯身手嗎,你想得到更專業的認可嗎?快來報名參加AP-220資格認證考試進一步提高自己的技能吧。NewDumps可以幫助你實現這一願望。這裏有專業的知識,強大的考古題,優質的服務,可以讓你高速高效的掌握知識技能,在考試中輕鬆過關,讓自己更加接近成功之路。
