Build ARM Trusted Firmware from source + use JTAG on RK3399
52
Posted at 9/19/2017 02:31:42      View:3899 | Replies:2        Print      Only Author   [Copy Link] 1#
I have two question:
1. Where is the source code so that I can build ARM Trusted Frimware (bl31.bin) from source? I need to modify ATF in order to run some code at EL3.
I have tried using https://github.com/ARM-software/arm-trusted-firmware but there is no instruction on how to build it for this particular board. Are there any specific build options?
2. How do I use JTAG on RK3399? There seems to be no guide on this. Thanks.
Posted at 11/13/2017 07:25:19        Only Author  2#
Hi Tuan, did you ever figure this out in the end?
Posted at 11/14/2017 15:38:50        Only Author  3#
Rockchip seems to be maintaining a repo and it is quite active. Link is given below.
https://github.com/rockchip-linux/arm-trusted-firmware
I'm not fully aware between the differences between this and the one maintained by ARM. Just FYI, you can explore further.
Thanks,
San
