Unable to find SATA3.0 harddrive with Firefly PCIe M.2-adapter
26
Posted at 10/24/2017 15:24:35      View:4078 | Replies:5        Print      Only Author   [Copy Link] 1#
Hello!
I am having problems finding / indentifying / communicating with my 1TB Seagate Barracuda 2.5"-harddrive, that I have connected to my Firefly RK3399. I am using this PCIe M.2 to SATA3.0-adapter board (http://shop.t-firefly.com/goods.php?id=52), and my HDD is connected with SATA to this adapter.
Listing available disk partitions with 'lsblk' shows no sign of the drive, and monitoring 'dmesg' while plugging the HDD power out, then back in, shows no errors or warnings.
Using 'lspci' I get:
00:00.0 PCI bridge: Device 1d87:0100
01:00.0 IDE interface: ASMedia Technology Inc. ASM1061 SATA IDE Controller (rev 02)
I have read this thread: http://bbs.t-firefly.com/forum.p ... p;extra=&page=1
Learning from this I can already say:
1) I find no "/dev/block/nvme0n1p1" which Isle suggests.
2) "Mmind" suggests some solutions on page 2 and on, and I have tried the same without luck.
I am wondering if the adapter is actually supported in the latest kernel, if anyone have similar issues, and if anyone has either a long-term or short-term fix for my problem.
Posted at 10/25/2017 16:21:23        Only Author  2#
I suggest you try the newest firmware of Android7.1
Posted at 10/27/2017 03:10:43        Only Author  3#
I am also having this issue. My plan is to boot a debian OS from the sata hard-disk, but for that I guess U-Boot will need to be able to work with the SATA chip. Can anybody tell me if U-Boot will be able to boot the kernel from a SATA disk?
Posted at 1/11/2026 08:44:37        Only Author  4#
Such an insightful article, I’m thankful for your sharing. N16302GC10 hot spot questions questions are essential for your career success—get them for free!
Posted at 1/14/2026 04:05:18        Only Author  5#
Your article was truly enlightening and inspiring, thank you! The Latest CCM test papers questions are essential for your promotion and salary increase—free now!
Posted at 1/16/2026 08:42:07        Only Author  6#
I sincerely thank you for sharing such a powerful article! The 300-415 valid practice questions pdf resources are highly valuable and free.
