SDcard Linux image for RK3288?
14
Posted at 11/3/2017 09:56:38      View:7547 | Replies:6        Print      Only Author   [Copy Link] 1#
Please, where can I find the image file to boot from the SDcard in RK3288? There is no such file on t-firefly.com.
Posted at 11/6/2017 21:55:00        Only Author  2#
I need too, one sd card version of ubuntu server. Somebody can help us? Cheers
Posted at 11/15/2017 17:41:46        Only Author  3#
The operation is a bit troublesome.
first, you will upgrade this bootloader. if on linux,
  1. sudo upgrade_tool ul RK3288UbootLoader_V2.30.10_Erase_emmc_idb.bin
Copy the code
Then the board do not boot from emmc, if you restart the board.
Second, Insert SD card to PC and we assume the /dev/sdb is the SD card device,
  1. sudo dd if=SD.img of=/dev/sdb
Copy the code
Finally, insert sd card to rk3288, restart.
note: if you need the rk3288 boot from emmc, you will execute this command:
  1. sudo upgrade_tool ul rk3288_bootloader_v1.00.06.bin
Copy the code
upgrade_tool:    http://en.t-firefly.com/doc/product/info/id/231.html
resource:            链接: https://pan.baidu.com/s/1nuHel8P 密码: 62bd
Posted at 1/9/2026 17:03:15        Only Author  4#
I learned so much from the article—it was truly beneficial. Enhance your IT abilities and grab free 300-215 valid exam sample. Wishing you all the best!
Posted at 1/10/2026 10:55:02        Only Author  5#
It was such a valuable learning experience. Sharing Reliable DEP-2025 braindumps questions exam questions for free—promotions and salary growth await!
Posted at 1/15/2026 09:00:12        Only Author  6#
What a powerful piece, thank you for sharing this inspiring article! We’ve made Project-Planning-Design new test collection free available, packed with useful content, to help you, free of charge.
Posted at 1/27/2026 14:41:14        Only Author  7#
Great stuff, I’m liking this without question. Sharpen your IT skills with free Latest test C-THR82-2505 dumps free. Wishing you the best in everything!
