New Topic
Flash image download link is broken
145
Posted at 11/3/2017 17:39:15      View:9218 | Replies:15        Print      Only Author   [Copy Link] 1#
Hi,
The below given link which is referred from the "Flash_image"  page is broken. Could someone help?
http://en.t-firefly.com/en/firenow/Firefly_RK3399/download/
Thanks,
San
Posted at 11/5/2017 01:40:37        Only Author  2#
I got the link of the google drive https://drive.google.com/drive/f ... gAqASHJLWW1xbkhyWms
Thanks,
San
Posted at 11/17/2017 15:27:36        Only Author  3#
Posted at 11/18/2017 04:33:56        Only Author  4#
After wasting 3 hours am still in the same place.
The update tool does not work. .. Really this is waste of time.
1. Link - https://drive.google.com/drive/f ... gAqAc0dPSWdGSnZIejA
On ubuntu it .. here is exact command line.
manuyareshimi@manuyareshimi-ubuntu-MacPro:~/Documents/fix_rk3399_issues/images/Linux_Upgrade_Tool_v1.24$ ls
config.ini  Linux┐к╖в╣д╛▀╩╣╙├╩╓▓с_v1.0.pdf  upgrade_tool
manuyareshimi@manuyareshimi-ubuntu-MacPro:~/Documents/fix_rk3399_issues/images/Linux_Upgrade_Tool_v1.24$ chmod 755 upgrade_tool
manuyareshimi@manuyareshimi-ubuntu-MacPro:~/Documents/fix_rk3399_issues/images/Linux_Upgrade_Tool_v1.24$ sudo ./upgrade_tool
sudo: unable to execute ./upgrade_tool: No such file or directory
Hangup
manuyareshimi@manuyareshimi-ubuntu-MacPro:~/Documents/fix_rk3399_issues/images/Linux_Upgrade_Tool_v1.24$ ./upgrade_tool
bash: ./upgrade_tool: No such file or directory
Posted at 11/18/2017 04:35:45        Only Author  5#
Even i try to put in /usr/local/bin - still similar issue
manuyareshimi@manuyareshimi-ubuntu-MacPro:~/Documents/fix_rk3399_issues/images/Linux_Upgrade_Tool_v1.24$ sudo cp upgrade_tool /usr/local/bin
manuyareshimi@manuyareshimi-ubuntu-MacPro:~/Documents/fix_rk3399_issues/images/Linux_Upgrade_Tool_v1.24$ sudo chown root:root /usr/local/bin/upgrade_tool
manuyareshimi@manuyareshimi-ubuntu-MacPro:~/Documents/fix_rk3399_issues/images/Linux_Upgrade_Tool_v1.24$ sudo upgrade_tool
sudo: unable to execute /usr/local/bin/upgrade_tool: No such file or directory
Hangup
Posted at 11/18/2017 04:36:53        Only Author  6#
When i looked online - this happens when an application is not working well... Linux is also a bad os, that it does not give right messages..
Anyways, do you have ideas.. or am i going to waste more time.??
Posted at 11/19/2017 22:14:05        Only Author  7#
Hej there,
Is it possible to share the new xubuntu.img from baidu to googledrive?
https://pan.baidu.com/s/1hsOCOJU ... 2FFirmware%2FUbuntu
i can′t understood this and direkt download isn′t supported
Posted at 11/20/2017 10:43:39        Only Author  8#
http://bbs.t-firefly.com/forum.p ... ight=upgrade%2Btool
Posted at 11/20/2017 11:09:43        Only Author  9#
Tholo Posted at 11/19/2017 22:14
Hej there,
uploading google driver.
Posted at 11/20/2017 11:39:52        Only Author  10#
Hej there,
https://drive.google.com/open?id ... 9x9_9Owzy15thfvOfSu    Firefly-RK3399-xubuntu
Return to List
12
