New Topic
Please document how exactly a latest RK3399 Ubuntu rootfs is built
112
Posted at 12/9/2017 21:13:42      View:10942 | Replies:13        Print      Only Author   [Copy Link] 1#
Currently there is a page related to RK3399 rootfs (http://wiki.t-firefly.com/index. ... Build_Ubuntu_rfs/en ) but this is severely out-dated. Following this guide, a system with nearly no working device will be built.
I tried the latest official Xubuntu image and it works well, but when I built my own rootfs with the official document, none of the following devices work properly:
1. Bluetooth
    Possibly missing firmware and /usr/local/bin/enable_bt ?
2. WiFi
    Firmware missing
3. GPU (OpenGL ES, libmali)
    I can see libmali-rk-midgard-dev and libmali-rk-midgard-4th-r13p0 in official Xubuntu rootfs, but copying libEGL.so/libGLESv2.so/etc. to my own rootfs results in "EGLUT: Failed to initialize EGL display" when running es2gears. doing a dpkg-repack results the same.
    Where can I download/create the libmali-rk-midgard-dev & libmali-rk-midgard-4th-r13p0 deb packages? How should them be installed?
4. Sound (rt5640)
    Device shows up, but no sound output.
5. Hardware video decoding
Adding rockchip firmware overlay (https://github.com/rockchip-linux/rk-rootfs-build) on GitHub will get WiFi working, but I googled for hours with no luck for other devices.
Posted at 12/12/2017 17:54:59        Only Author  2#
The above bug is based on the original rootfs made some changes
Posted at 12/12/2017 23:22:58        Only Author  3#
luvings Posted at 12/12/2017 17:54
I managed to get sound working by restoring an "asound.state" provided by a friend of mine. Others are still not working.
That's not what an open source platform should be like. Everything should be well documented instead of a single Xubuntu img.
I'm also stuck at getting mainline u-boot & u-boot spl working so that I can use extlinux (which is significantly easier to play with & updating mainline kernel) instead of the heavily modified firefly u-boot, and I wonder if I could find some related doc or guide to get this working.
I saw firefly-rk3399 related packages in Debian and openSUSE repos, but there's not even a single doc/guide.
Posted at 12/13/2017 16:02:29        Only Author  4#
the process  of making rootfs is really not good record.
Menu->Multimedia->PulseAudio Volume Control->Configuration->select one card working, close anothers
asound.state.rar
1.62 KB, Down times: 11
Posted at 12/14/2017 16:02:40        Only Author  5#
About GPU (OpenGL ES)
You should link libmali.so\libEGL.so to libmali-rk-midgard-4th-r13p0.so
Posted at 12/15/2017 01:27:56        Only Author  6#
Rudis Posted at 12/14/2017 16:02
The "EGLUT: Failed to initialize EGL display" error only ocurred when I linked both files. if I don't do that, it will either use mesa EGL and software rendering, or show an error indicating it cannot load libEGL, if no mesa libEGL is present.
Posted at 12/16/2017 16:01:41        Only Author  7#
Actually glmark2-es2-drm is working (full screen), but glmark2-es2 fails with EGLUT 0x3003, which means the display is not initialized, so I think that's some issue related to X11 DDX.
Posted at 12/16/2017 22:02:12        Only Author  8#
Well, I found that the official Xubuntu image is using custom X11 server. Maybe missing the (rockchip modified) X11 is the root cause.
Posted at 12/18/2017 09:06:45        Only Author  9#
You can find the libmali for X11 on https://github.com/rockchip-linux/libmali
The marching version is libmali-midgard-t86x-r13p0.so https://github.com/rockchip-linu ... b/aarch64-linux-gnu
I had tested it before.
Posted at 12/18/2017 09:23:32        Only Author  10#
You can try it.
You can modify /usr/include/EGL/eglplatform.h
  1.     struct gbm_device;
  2.     struct gbm_surface;
  3.     typedef struct gbm_device * EGLNativeDisplayType;
  4.     typedef struct gbm_surface * EGLNativeWindowType;
  5.     typedef void * EGLNativePixmapType;
  6.     /* EGL 1.2 types, renamed for consistency in EGL 1.3 */
  7.     typedef EGLNativeDisplayType NativeDisplayType;
  8.     typedef EGLNativePixmapType  NativePixmapType;
  9.     typedef EGLNativeWindowType NativeWindowType;
Copy the code
to
  3.     #if defined(__GBM__)
  4.     typedef struct gbm_device * EGLNativeDisplayType;
  5.     typedef struct gbm_surface * EGLNativeWindowType;
  6.     typedef void * EGLNativePixmapType;
  7.     #elif defined(__unix__)
  8.     #include <X11/Xlib.h>
  9.     #include <X11/Xutil.h>
  10.     typedef Display *EGLNativeDisplayType;
  11.     typedef Pixmap EGLNativePixmapType;
  12.     typedef Window EGLNativeWindowType;
  13.     #endif
  14.     typedef EGLNativeWindowType NativeWindowType;
  15.     typedef EGLNativePixmapType NativePixmapType;
  16.     typedef EGLNativeDisplayType NativeDisplayType;
Copy the code
Return to List
12
